Learning distance functions using equivalence relations, pp.3-11, 2003. ,
Integrating constraints and metric learning in semi-supervised clustering, Twenty-first international conference on Machine learning , ICML '04, 2004. ,
DOI : 10.1145/1015330.1015360
Learning a distance metric from relative comparisons, Advances in Neural Information Processing Systems, 2004. ,
Distance metric learning with kernels, Proceedings of the International Conference on Artificial Intelligence, 2003. ,
Learning metrics via discriminant kernels and multidimensional scaling: Toward expected euclidean representation, ICML'03, 2003. ,
Using clustering to learn distance functions for supervised similarity assessment, International Conference on Machine Learning and Data Mining, 2005. ,
Nonlinear Dimensionality Reduction by Locally Linear Embedding, Science, vol.290, issue.5500, pp.2323-2326, 2000. ,
DOI : 10.1126/science.290.5500.2323
URL : http://astro.temple.edu/~msobel/courses_files/saulmds.pdf
Out-of-sample extensions for LLE, Isomap, MDS, eigenmaps, and spectral clustering, 2003. ,
Distance metric learning with applications to clustering with side information, Advances in Neural Information Processing Systems, p.15, 2003. ,
Adjustment Learning and Relevant Component Analysis, p.2, 2002. ,
DOI : 10.1007/3-540-47979-1_52
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.19.2871
A metric for ARMA processes, IEEE Transactions on Signal Processing, vol.48, issue.4, pp.1164-1170, 2000. ,
DOI : 10.1109/78.827549
Subspace angles and distances between arma models, Systems and Control Letters, 2002. ,
Unstable systems and feedback: The gap metric, Proc. 18th Allerton Conference on Communications, Control, and Computers, pp.380-385, 1980. ,
A ??-gap distance for uncertain and nonlinear systems, Proceedings of the 38th IEEE Conference on Decision and Control (Cat. No.99CH36304), 1999. ,
DOI : 10.1109/CDC.1999.831313
The graph metric for unstable plants and robustness estimates for feedback stability, AC, vol.29, pp.403-417, 1984. ,
Hilbert space embeddings in dynamical systems, Proc. of IFAC'03, pp.760-767, 2003. ,
On Information and Sufficiency, The Annals of Mathematical Statistics, vol.22, issue.1, pp.79-86, 1951. ,
DOI : 10.1214/aoms/1177729694
The CMU motion of body (Mobo) database, CMU, 2001. ,
Identifiability, recursive identification and spaces of linear dynamical systems. CWI Tracts, pp.63-64, 1989. ,
DIFFERENTIAL GEOMETRY OF ARMA MODELS, Journal of Time Series Analysis, vol.46, issue.3, pp.11-259, 1990. ,
DOI : 10.1016/0047-259X(86)90055-2
Fisher optimal approximation of an AR(n)-process by an AR(n-1)- process, Proceedings of ECC'93, pp.1225-1229, 1993. ,
Metric learning for text documents, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.28, issue.4, pp.497-508, 2006. ,
DOI : 10.1109/TPAMI.2006.77
Differential geometric methods in statistics, 1985. ,
Differential Geometry and Statistics, 1993. ,
Semi-Supervised Learning on Riemannian Manifolds, Machine Learning, vol.56, issue.1-3, pp.209-239, 2004. ,
DOI : 10.1023/B:MACH.0000033120.25363.1e
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.78.2757
Aspects of Fisher geometry for stochastic linear systems, problem 25, Open Problems in Mathematical Systems and Control Theory, pp.27-30, 2002. ,
ON THE RIEMANNIAN MANIFOLD STRUCTURE OF CLASSES OF LINEAR SYSTEMS, EQUADIFF 2003, p.2003, 2003. ,
DOI : 10.1142/9789812702067_0096
