Single-Input Eigenvalue Assignment Algorithms: A Close Look, SIAM Journal on Matrix Analysis and Applications, vol.19, issue.2, pp.444-467, 1998. ,
DOI : 10.1137/S0895479895294885
Etude de différentes méthodes d'assimilation de données pour l'environnement, 2003. ,
Data assimilation methods for an oceanographic problem XVI of Mathematics in Industry Series: Multidisciplinary methods for analysis, optimization and control of complex systems, pp.179-194, 2004. ,
Back and forth nudging algorithm for data assimilation problems, Comptes Rendus Mathematique, vol.340, issue.12, pp.873-878, 2005. ,
DOI : 10.1016/j.crma.2005.05.006
URL : https://hal.archives-ouvertes.fr/inria-00189644
An Adjoint Examination of a Nudging Method for Data Assimilation, Monthly Weather Review, vol.125, issue.6, pp.1355-1373, 1997. ,
DOI : 10.1175/1520-0493(1997)125<1355:AAEOAN>2.0.CO;2
Assimilation of TOPEX/POSEIDON altimeter data into a circulation model of the North Atlantic, Journal of Geophysical Research, vol.81, issue.C12, pp.691-715, 1994. ,
DOI : 10.1029/94JC01644
Commande et optimisation de systèmes dynamiques, LesÉditionsLes´LesÉditions de l' ´ Ecole Polytechnique, 2005. ,
An algorithm to assign eigenvalues in a Hessenberg matrix: Single input case, IEEE Transactions on Automatic Control, vol.32, issue.5, pp.414-417, 1987. ,
DOI : 10.1109/TAC.1987.1104622
Estimating the covariance matrix of analysis and forecast error in variational data assimilation, 1995. ,
Some numerical experiments with variable-storage quasi-Newton algorithms, Mathematical Programming, vol.11, issue.2, pp.407-435, 1989. ,
DOI : 10.1007/BF01589113
The Initialization of Numerical Models by a Dynamic-Initialization Technique, Monthly Weather Review, vol.104, issue.12, pp.1551-1556, 1976. ,
DOI : 10.1175/1520-0493(1976)104<1551:TIONMB>2.0.CO;2
The Role of Mesoscale Eddies in the General Circulation of the Ocean???Numerical Experiments Using a Wind-Driven Quasi-Geostrophic Model, Journal of Physical Oceanography, vol.8, issue.3, pp.363-392, 1978. ,
DOI : 10.1175/1520-0485(1978)008<0363:TROMEI>2.0.CO;2
Application of the Quasi-Inverse Method to Data Assimilation, Monthly Weather Review, vol.128, issue.3, pp.864-875, 2000. ,
DOI : 10.1175/1520-0493(2000)128<0864:AOTQIM>2.0.CO;2
Variational algorithms for analysis and assimilation of meteorological observations: theoretical aspects, Tellus A, vol.109, issue.2, pp.97-110, 1986. ,
DOI : 10.1111/j.1600-0870.1986.tb00459.x
Deterministic Nonperiodic Flow, Journal of the Atmospheric Sciences, vol.20, issue.2, pp.130-141, 1963. ,
DOI : 10.1175/1520-0469(1963)020<0130:DNF>2.0.CO;2
Observers for multivariable systems, IEEE Transactions on Automatic Control, vol.11, issue.2, pp.190-197, 1966. ,
DOI : 10.1109/TAC.1966.1098323
A variational method for the resolution of a data assimilation problem in oceanography, Inverse Problems, vol.14, issue.4, pp.979-997, 1998. ,
DOI : 10.1088/0266-5611/14/4/014
Updating quasi-Newton matrices with limited storage, Mathematics of Computation, vol.35, issue.151, pp.773-782, 1980. ,
DOI : 10.1090/S0025-5718-1980-0572855-7
On extending the limits of variational assimilation in nonlinear chaotic systems, pp.96-121, 1996. ,
Optimal determination of nudging coefficients using the adjoint equations, pp.358-369, 1993. ,
Use of Four-Dimensional Data Assimilation in a Limited-Area Mesoscale Model. Part I: Experiments with Synoptic-Scale Data, Monthly Weather Review, vol.118, issue.6, pp.1250-1277, 1990. ,
DOI : 10.1175/1520-0493(1990)118<1250:UOFDDA>2.0.CO;2
A study of the dynamics of four-dimensional data assimilation, pp.43-60, 1981. ,
On the mathematics of data assimilation, pp.321-339, 1981. ,
Contrôle optimal: théorie et applications, 2005. ,
Altimeter data assimilation into an ocean circulation model: Sensitivity to orbital parameters, Journal of Geophysical Research, vol.78, issue.1, pp.443-459, 1990. ,
DOI : 10.1029/JC095iC07p11443
Impact de données d'altimétrie satellitaire sur les simulations numériques des circulations générales océaniques aux latitudes moyennes, pp.31-46, 1989. ,
Assimilation of Geosat data into a quasigeostrophic model of the North Atlantic between 20 o N and 50 o N: preliminary results, Oceanol. Acta, vol.15, issue.5, pp.575-583, 1992. ,
Determination of optimal nudging coefficients, pp.1-15, 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00325360
An Optimal Nudging Data Assimilation Scheme Using Parameter Estimation, Quarterly Journal of the Royal Meteorological Society, vol.116, issue.508, pp.1163-1186, 1992. ,
DOI : 10.1002/qj.49711850808
