The Probabilistic Method, Wiley-Intersci. Ser. Discrete Math. Optim, 2008. ,
Weighted sums of certain dependent random variables, Tohoku Mathematical Journal, vol.19, issue.3, pp.357-367, 1967. ,
DOI : 10.2748/tmj/1178243286
Labelings of Graphs with Fixed and Variable Edge-Weights, SIAM Journal on Discrete Mathematics, vol.21, issue.3, pp.688-706, 2007. ,
DOI : 10.1137/040619545
Labeling planar graphs with a condition at distance two, European Journal of Combinatorics, vol.28, issue.8, pp.2201-2239, 2007. ,
DOI : 10.1016/j.ejc.2007.04.019
URL : https://hal.archives-ouvertes.fr/hal-01184374
Backbone colorings for graphs: Tree and path backbones, Journal of Graph Theory, vol.94, issue.2, pp.55-137, 2007. ,
DOI : 10.1002/jgt.20228
The L(h, k)-Labelling Problem: An Updated Survey and Annotated Bibliography, The Computer Journal, vol.54, issue.8, pp.1344-1371, 2011. ,
DOI : 10.1093/comjnl/bxr037
The $L(2,1)$-Labeling Problem on Graphs, SIAM Journal on Discrete Mathematics, vol.9, issue.2, pp.309-316, 1996. ,
DOI : 10.1137/S0895480193245339
Problems and results on 3-chromatic hypergraphs and some related questions, Infinite and Finite Sets, pp.609-627, 1975. ,
Relating path coverings to vertex labellings with a condition at distance two, Discrete Mathematics, vol.135, issue.1-3, pp.103-111, 1994. ,
DOI : 10.1016/0012-365X(93)E0098-O
On the <mml:math altimg="si7.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mi mathvariant="normal">L</mml:mi><mml:mo stretchy="false">(</mml:mo><mml:mi>p</mml:mi><mml:mo>,</mml:mo><mml:mn>1</mml:mn><mml:mo stretchy="false">)</mml:mo></mml:math>-labelling of graphs, Discrete Mathematics, vol.308, issue.8, pp.1405-1414, 2008. ,
DOI : 10.1016/j.disc.2007.07.075
Graph labellings with variable weights, a survey, Discrete Applied Mathematics, vol.157, issue.12, pp.2646-2658, 2009. ,
DOI : 10.1016/j.dam.2008.08.024
Labelling Graphs with a Condition at Distance 2, SIAM Journal on Discrete Mathematics, vol.5, issue.4, pp.586-595, 1992. ,
DOI : 10.1137/0405048
On Moore Graphs with Diameters 2 and 3, IBM Journal of Research and Development, vol.4, issue.5, pp.497-504, 1960. ,
DOI : 10.1147/rd.45.0497
Graph Coloring Analogues with a Condition at Distance Two: L(2, 1)-Labelings and List ?-Labelings, 1993. ,
Bounds for the real number graph labellings and application to labellings of the triangular lattice, SIAM J. Discrete Math, vol.22, pp.1559-1569, 2008. ,
A theorem about the channel assignment problem, SIAM J ,
Circular Distance Two Labeling and the $\lambda$-Number for Outerplanar Graphs, SIAM Journal on Discrete Mathematics, vol.19, issue.2, pp.281-293, 2005. ,
DOI : 10.1137/S0895480102414296
On the method of bounded differences, Surveys in Combinatorics, pp.148-188, 1989. ,
DOI : 10.1017/CBO9781107359949.008
Concentration for Independent Permutations, Combinatorics, Probability and Computing, vol.11, issue.02, pp.163-178, 2002. ,
DOI : 10.1017/S0963548301005089
Colouring graphs when the number of colours is almost the maximum degree, Journal of Combinatorial Theory, Series B, vol.109 ,
DOI : 10.1016/j.jctb.2014.06.004
Graph Colouring and the Probabilistic Method, Algorithms Combin, vol.23, 2002. ,
DOI : 10.1007/978-3-642-04016-0
Concentration of measure and isoperimetric inequalities in product spaces, Publications math??matiques de l'IH??S, vol.19, issue.158, pp.73-205, 1995. ,
DOI : 10.1007/BF02699376
Coloring the square of a planar graph, Journal of Graph Theory, vol.7, issue.2, pp.110-124, 2003. ,
DOI : 10.1002/jgt.10077
A survey on labeling graphs with a condition at distance two, Discrete Mathematics, vol.306, issue.12, pp.1217-1231, 2006. ,
DOI : 10.1016/j.disc.2005.11.029
