G. Alefeld and J. Herzberger, Introduction to interval computations, 1983.
G. Alefeld and G. Mayer, Interval analysis: theory and applications, Journal of Computational and Applied Mathematics, vol.121, issue.1-2, pp.421-464, 2000.
DOI : 10.1016/S0377-0427(00)00342-3
O. Beaumont, Algorithmique pour les intervalles : Comment obtenir un résultat sur quand les données sont incertaines, 1999.
L. Busé, H. Khalil, and B. Mourrain, Resultant-Based Methods for Plane Curves Intersection Problems, Proc. 8th Int. Workshop Computer Algebra in Scientific Computing, pp.75-92, 2005.
DOI : 10.1007/11555964_7
D. Chablat, P. Wenger, F. Majou, and J. Merlet, An Interval Analysis Based Study for the Design and the Comparison of Three-Degrees-of-Freedom Parallel Kinematic Machines, The International Journal of Robotics Research, vol.23, issue.6, pp.615-624, 2004.
DOI : 10.1177/0278364904044079
D. Cox, J. Little, and D. Shea, Ideals, Varieties, and Algorithms. Undergraduate Texts in Mathematics, 1997.
A. Deif and J. Rohn, On the invariance of the sign pattern of matrix eigenvectors under perturbation, Linear Algebra and its Applications, vol.196, pp.63-70, 1994.
DOI : 10.1016/0024-3795(94)90315-8
A. S. Deif, The Interval Eigenvalue Problem, ZAMM - Journal of Applied Mathematics and Mechanics / Zeitschrift f??r Angewandte Mathematik und Mechanik, vol.35, issue.1, pp.61-64, 1991.
DOI : 10.1002/zamm.19910710117
A. D. Dimarogonas, Interval analysis of vibrating systems, Journal of Sound and Vibration, vol.183, issue.4, pp.739-749, 1995.
DOI : 10.1006/jsvi.1995.0283
I. Z. Emiris, B. Mourrain, and E. P. Tsigaridas, Real Algebraic Numbers: Complexity Analysis and Experimentation, Reliable Implementations of Real Number Algorithms: Theory and Practice, pp.57-82
DOI : 10.1007/978-3-540-85521-7_4
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.101.9180
F. Gioia and C. N. Lauro, Principal component analysis on interval data, Computational Statistics, vol.104, issue.1, pp.343-363, 2006.
DOI : 10.1007/s00180-006-0267-6
E. Hansen and G. W. Walster, Global optimization using interval analysis, revised and expanded, 2004.
E. R. Hansen and G. W. Walster, Sharp bounds on interval polynomial roots, Reliable Computing, vol.8, issue.2, pp.115-122, 2002.
DOI : 10.1023/A:1014797921296
C. Jansson and J. Rohn, An Algorithm for Checking Regularity of Interval Matrices, SIAM Journal on Matrix Analysis and Applications, vol.20, issue.3, pp.756-776, 1999.
DOI : 10.1137/S0895479896313978
L. Jaulin, M. Kieffer, O. Didrit, and . Walter, Applied interval analysis . With examples in parameter and state estimation, robust control and robotics, 2001.
URL : https://hal.archives-ouvertes.fr/hal-00845131
W. Karl, J. Greschak, and G. Verghese, Comments on ??? A necessary and sufficient condition for the stability of interval matrices ??????, International Journal of Control, vol.14, issue.4, pp.849-851, 1984.
DOI : 10.1080/00207178408933211
O. Knüppel, D. Husung, and C. Keil, PROFIL/BIAS ? a C++ class library
W. Krandick, Isolierung reeller nullstellen von polynomen, Wissenschaftliches Rechnen, pp.105-154, 1995.
A. Neumaier, Interval methods for systems of equations, 1990.
DOI : 10.1017/CBO9780511526473
S. Poljak and J. Rohn, Checking robust nonsingularity is NP-hard, Mathematics of Control, Signals, and Systems, vol.126, issue.1, pp.1-9, 1993.
DOI : 10.1007/BF01213466
Z. Qiu, P. C. Müller, and A. Frommer, An approximate method for the standard interval eigenvalue problem of real non-symmetric interval matrices, Communications in Numerical Methods in Engineering, vol.31, issue.4, pp.239-251, 2001.
DOI : 10.1002/cnm.401
G. Rex and J. Rohn, Sufficient Conditions for Regularity and Singularity of Interval Matrices, SIAM Journal on Matrix Analysis and Applications, vol.20, issue.2, pp.437-445, 1998.
DOI : 10.1137/S0895479896310743
J. Rohn, Interval Matrices: Singularity and Real Eigenvalues, SIAM Journal on Matrix Analysis and Applications, vol.14, issue.1, pp.82-91, 1993.
DOI : 10.1137/0614007
J. Rohn, Bounds on Eigenvalues of Interval Matrices, ZAMM - Journal of Applied Mathematics and Mechanics / Zeitschrift f??r Angewandte Mathematik und Mechanik, vol.78, issue.S3, pp.1049-1050, 1998.
DOI : 10.1002/zamm.19980781593
J. Rohn, Solvability of systems of interval linear equations and inequalities, Linear optimization problems with inexact data., chapter 2, pp.35-77
DOI : 10.1007/0-387-32698-7_2
J. Rohn and A. Deif, Zur Einschliessung der Eigenwerte einer Intervallmatrix, Computing, vol.70, issue.3-4, pp.373-377, 1992.
DOI : 10.1007/BF02320205
F. Rouillier and Z. Zimmermann, Efficient isolation of polynomial's real roots, Journal of Computational and Applied Mathematics, vol.162, issue.1, pp.33-50, 2004.
DOI : 10.1016/j.cam.2003.08.015
H. Stetter, Numerical Polynomial Algebra, Society for Industrial Mathematics, 2004.
DOI : 10.1137/1.9780898717976
