Complexity of the delaunay triangulation of points on surfaces the smooth case, Proceedings of the nineteenth conference on Computational geometry , SCG '03, 2003. ,
DOI : 10.1145/777792.777823
Topologically certified approximation of umbilics and ridges on polynomial parametric surface, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00071225
The implicit structure of ridges of a smooth parametric surface To appear in CAGD. [CP05] F. Cazals and M. Pouget. Topology driven algorithms for ridge extraction on meshes, INRIA, 2005. [dC76] M. de Carmo. Differential Geometry of Curves and Surfaces Faugère. A new efficient algorithm for computing gröbner bases (f4). Journal of Pure and Applied Algebra, pp.1-361, 1976. ,
A new efficient algorithm for computing gröbner bases without reduction to zero f5, International Symposium on Symbolic and Algebraic Computation Symposium -ISSAC 2002, 2002. ,
Computing the topology of 3-dimensional algebraic curves, Computational Methods for Algebraic Spline Surfaces, pp.27-44, 2004. ,
Third Order Invariants of Surfaces, Computational methods for algebraic spline surfaces, 2005. ,
DOI : 10.1007/3-540-27157-0_14
Efficient topology determination of implicitly defined algebraic plane curves, Computer Aided Geometric Design, vol.19, issue.9, 2002. ,
DOI : 10.1016/S0167-8396(02)00167-X
Geometry and the Imagination Two-and Three- Dimensional Patterns of the Face, HGY + 99]Koe90] J.J. Koenderink. Solid Shape. MIT, 1952. ,
Symmetry of Curves and the Geometry of Surfaces: two Explorations with the aid of Computer Graphics, 1990. ,
The sub-parabolic lines of a surface, Mathematics of Surfaces VI, IMA new series 58, pp.79-102, 1996. ,
Umbilics and lines of curvature for shape interrogation, Computer Aided Geometric Design, vol.13, issue.2, pp.133-161, 1996. ,
DOI : 10.1016/0167-8396(95)00018-6
Landmark-based registration using features identified through differential geometry Handbook of Medical Imaging [Por71] I. Porteous. The normal singularities of a submanifold, Por01] I. Porteous. Geometric Differentiation, 1971. ,
Solving Zero-Dimensional Systems Through the Rational Univariate Representation, Applicable Algebra in Engineering, Communication and Computing, vol.9, issue.5, pp.433-46133, 1999. ,
DOI : 10.1007/s002000050114
URL : https://hal.archives-ouvertes.fr/inria-00073264
On the exact computation of the topology of real algebraic curves The extremal mesh and the understanding of 3d surfaces, SCG '05: Proceedings of the twenty-first annual symposium on Computational geometry, pp.107-115115, 1996. ,
