JML-Testing-Tools: a Symbolic Animator for JML Specifications using CLP
This paper describes a tool for symbolically animating JML specifications using Constraint Logic Programming. A customized solver handles constraints that represent the value of instance fields. We have extended a model-based approach to be able to handle object-oriented specifications. Our tool is also able to check properties during the simulation and exhibit counter-examples for false properties. Therefore, it can be used both for semi-automated verification and for validation purposes.
