JML-Testing-Tools: a Symbolic Animator for JML Specifications using CLP - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
This paper describes a tool for symbolically animating JML specifications using Constraint Logic Programming. A customized solver handles constraints that represent the value of instance fields. We have extended a model-based approach to be able to handle object-oriented specifications. Our tool is also able to check properties during the simulation and exhibit counter-examples for false properties. Therefore, it can be used both for semi-automated verification and for validation purposes.
inria-00329995 , version 1 (13-10-2008)
Fabrice Bouquet, Frédéric Dadeau, Bruno Legeard, Marc Utting. JML-Testing-Tools: a Symbolic Animator for JML Specifications using CLP. International Conference on Tools and Algorithms for the Construction and Analysis of Systems - TACAS'05, Apr 2005, Edinburgh, United Kingdom. pp.551-556, ⟨10.1007/b107194⟩. ⟨inria-00329995⟩
155 Consultations
0 Téléchargements
