Least-Squares Fitting of Two 3-D Point Sets, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.9, issue.5, pp.698-700, 1987. ,
DOI : 10.1109/TPAMI.1987.4767965
The symmetry of faces. Vision Modeling and Visualization, pp.43-50, 2002. ,
A method for registration of 3-D shapes, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.14, issue.2, pp.239-256, 1992. ,
DOI : 10.1109/34.121791
Robust Euclidean alignment of 3D point sets: the trimmed iterative closest point algorithm, Image and Vision Computing, vol.23, issue.3, pp.299-309, 2005. ,
DOI : 10.1016/j.imavis.2004.05.007
An algorithm to map asymmetries of bilateral objects in point clouds, 2008 5th IEEE International Symposium on Biomedical Imaging: From Nano to Macro, 2008. ,
DOI : 10.1109/ISBI.2008.4541202
A new point matching algorithm for non-rigid registration, Computer Vision and Image Understanding, vol.89, issue.2-3, pp.114-141, 2003. ,
DOI : 10.1016/S1077-3142(03)00009-2
Maximum likelihood from incomplete data via the EM algorithm, JRSS, Series B, vol.39, issue.1, pp.1-38, 1977. ,
The Representation, Recognition, and Locating of 3-D Objects, The International Journal of Robotics Research, vol.5, issue.3, pp.27-52, 1986. ,
DOI : 10.1177/027836498600500302
Multi-scale EM-ICP: A Fast and Robust Approach for Surface Registration, ECCV, vol.2353, pp.418-432, 2002. ,
DOI : 10.1007/3-540-47979-1_28
URL : https://hal.archives-ouvertes.fr/inria-00615911
Closed-form solution of absolute orientation using unit quaternions, Journal of the Optical Society of America A, vol.4, issue.4, pp.629-642, 1987. ,
DOI : 10.1364/JOSAA.4.000629
Closed-form solution of absolute orientation using orthonormal matrices, Journal of the Optical Society of America A, vol.5, issue.7, pp.1127-1135, 1988. ,
DOI : 10.1364/JOSAA.5.001127
Robust matching of 3D contours using iterative closest point algorithm improved by M-estimation, Pattern Recognition, vol.36, issue.9, pp.2041-2047, 2003. ,
DOI : 10.1016/S0031-3203(03)00050-5
Robust midsagittal plane extraction from normal and pathological 3-D neuroradiology images, IEEE TMI, vol.20, issue.3, pp.175-192, 2001. ,
Automatic extraction of the mid-facial plane for cranio-maxillofacial surgery planning, International Journal of Oral and Maxillofacial Surgery, vol.35, issue.7, pp.636-642, 2006. ,
DOI : 10.1016/j.ijom.2006.01.028
Finding symmetry plane of 3D face shape, IEEE ICPR, pp.1143-1146, 2006. ,
A robust point-matching algorithm for autoradiograph alignment, Medical Image Analysis, vol.1, issue.4, pp.277-286, 1996. ,
DOI : 10.1016/S1361-8415(97)85008-6
3D symmetry detection using the extended gaussian image, IEEE PAMI, vol.19, issue.2, pp.164-168, 1997. ,
Statistical analysis of normal and abnormal dissymmetry in volumetric medical images, MedIA, vol.4, issue.2, pp.111-121, 2000. ,
URL : https://hal.archives-ouvertes.fr/inria-00615102
Shape from symmetry, Tenth IEEE International Conference on Computer Vision (ICCV'05) Volume 1, pp.1824-1831, 2005. ,
DOI : 10.1109/ICCV.2005.221
A Correlation-Based Approach to Robust Point Set Registration, IEEE ICCV, pp.558-569, 2005. ,
DOI : 10.1007/978-3-540-24672-5_44
Least-squares estimation of transformation parameters between two point patterns, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.13, issue.4, pp.376-380, 1991. ,
DOI : 10.1109/34.88573
Face authentication based on multiple profiles extracted from range data. Audio-and Video-Based Biometric Person Authentication, pp.515-522, 2003. ,
DOI : 10.1007/3-540-44887-x_61
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.261.3495
Symmetry as a continuous feature, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.17, issue.12, pp.1154-1166, 1995. ,
DOI : 10.1109/34.476508
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.33.4460
3D face authentication and recognition based on bilateral symmetry analysis. The Visual Computer, pp.43-55, 2006. ,
DOI : 10.1007/s00371-005-0352-9
URL : http://atic.asu.edu/data/docs_pubs/3d_face_authentication.pdf
