Abstract : Geometry textures are a novel geometric representation for surfaces based on height maps. The visualization is done through a GPU ray casting algorithm applied to the whole object. At rendering time, the fine-scale details (mesostructures) are reconstructed preserving original quality. Visualizing surfaces with geometry textures allows a natural LOD behavior. There are numerous applications that can benefit from the use of geometry textures. In this paper, besides a mesostructure visualization survey, we present geometry textures with three possible applications: rendering of solid models, geological surfaces visualization and surface smoothing.
