Using Skipping for Sequence-Based Collaborative Filtering
Recommender systems filter resources for a given user by predicting the most pertinent resource given a specific context. This paper describes a new approach of generating suitable recommendations based on the active user's navigation stream. The underlying hypothesis is that the resources order in the stream results from the intrinsic logic of the user's behavior. The Sequence Based Recommender we propose is inspired from Language Modeling and integrates skipping techniques. It has been tested on a browsing dataset extracted from Intranet logs provided by a French bank. Results show that the use of exponential decay weighting schemes when taking into account non contiguous sequences to compute recommendations enhances the accuracy. Moreover, we propose a skipping variant that provides a high accuracy while being less complex.
