Using Skipping for Sequence-Based Collaborative Filtering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Geoffray Bonnin
Armelle Brun
Anne Boyer
Recommender systems filter resources for a given user by predicting the most pertinent resource given a specific context. This paper describes a new approach of generating suitable recommendations based on the active user's navigation stream. The underlying hypothesis is that the resources order in the stream results from the intrinsic logic of the user's behavior. The Sequence Based Recommender we propose is inspired from Language Modeling and integrates skipping techniques. It has been tested on a browsing dataset extracted from Intranet logs provided by a French bank. Results show that the use of exponential decay weighting schemes when taking into account non contiguous sequences to compute recommendations enhances the accuracy. Moreover, we propose a skipping variant that provides a high accuracy while being less complex.
Fichier non déposé
inria-00332238 , version 1 (20-10-2008)
  • HAL Id : inria-00332238 , version 1
Geoffray Bonnin, Armelle Brun, Anne Boyer. Using Skipping for Sequence-Based Collaborative Filtering. IEEE/WIC/ACM International Conference on Web Intelligence, University of Technology, Dec 2008, Sydney, Australia. ⟨inria-00332238⟩
85 Consultations
0 Téléchargements
