A Characterization of NCk by First Order Functional Programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This paper is part of a research on static analysis in order to predict program resources and belongs to the implicit computational complexity line of research. It presents intrinsic characterizations of the classes of functions, which are computable in NCk, that is by a uniform, poly-logarithmic depth and polynomial size family of circuits, using first order functional programs. Our characterizations are new in terms of first order functional programming language and extend the characterization of NC1 in [9]. These characterizations are obtained using a complexity measure, the sup-interpretation, which gives upper bounds on the size of computed values and captures a lot of program schemas.
paper69.pdf (215.15 Ko) Télécharger le fichier
inria-00332390 , version 1 (20-10-2008)
Jean-Yves Marion, Romain Péchoux. A Characterization of NCk by First Order Functional Programs. 5th International Conference on Theory and Applications of Models of Computation - TAMC 2008, Xidian University, Apr 2008, Xian, China. pp.136-147, ⟨10.1007/978-3-540-79228-4⟩. ⟨inria-00332390⟩
118 Consultations
222 Téléchargements
