Towards a Constrained-based Verification of Parameterized Cryptographic Protocols
Although many works have been dedicated to standard protocols like Needham-Schroeder very few address the more challenging class of group protocol s. We present a synchronous model for group protocols, that generalizes standard protocol models by permitting unbounded lists inside messages. In this extended model we propose a correct and complete set of inference rules for checking security properties in presence of an active intruder for the class of well-tagged protocols. Our inference system generalizes the ones that are implemented in several tools for a bounded number of sessions and fixed size lists in message. In particular when applied to protocols whose specification does not contain unbounded lists our inference system provides a decision procedure for secrecy in the case of a fixed number of sessions.
Logique en informatique [cs.LO]
LOPSTR08-PostConference_Chridi-Turuani-Rusinowitch.pdf (212.21 Ko)
Télécharger le fichier
