Grid'5000: a large scale and highly reconfigurable experimental grid testbed, International Journal of High Performance Computing Applications, vol.20, issue.4, pp.481-494, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00684943
Diet: A scalable toolbox to build network enabled servers on the grid, International Journal of High Performance Computing Applications, vol.20, issue.3, pp.335-352, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00070406
The ARPEGE/IFS atmosphere model: a contribution to the french community climate modeling, Clim Dyn, vol.10, pp.249-266, 1994. ,
Association of parameter, software and hardware variation with large scale behavior across 57,000 climate models, Proceedings of the National Academy of Sciences, vol.104, pp.12259-12264, 2007. ,
An Adaptive Load Balancing Algorithm for Heterogeneous Distributed Systems with Multiple Task Classes, International Conference on Distributed Computing Systems, pp.629-636, 1996. ,
NEMO Reference manual, ocean dynamics component, 2006. ,
Design of Total Runoff Integrating Pathways (TRIP)-A Global River Channel Network, Earth Integration, vol.2, pp.1-37, 1234. ,
CPR: Mixed task and data parallel scheduling for distributed systems, IEEE International Parallel and Distributed Processing Symposium, p.39, 2001. ,
Low-cost mixed task and data parallel scheduling, 30-th International Conference on Parallel Processing (ICPP), pp.69-76, 2001. ,
A Framework for Exploiting Data and Functional Parallelism on Distributed Memory Multicomputers, vol.51, p.61801, 1994. ,
Compiler support for task scheduling in hierarchical execution models, Journal of Systems Architecture, vol.45, issue.6-7, pp.483-503, 1999. ,
Solving the Multidimensional Multiple Knapsack Problem with Packing constraints using Tabu Search, 1999. ,
Optimal use of mixed task and data parallelism for pipelined computations, Journal of Parallel and Distributed Computing, vol.60, issue.3, pp.297-319, 2000. ,
Oasis 3, user guide, Technical Report PRISM Report Serie, issue.2, 2004. ,
Scheduling multiple DAGs onto heterogeneous systems, IEEE International Parallel and Distributed Processing Symposium, p.6695, 2006. ,
, Unité de recherche INRIA Rhône-Alpes 655, avenue de l'Europe -38334 Montbonnot
, Parc Club Orsay Université -ZAC des Vignes 4, rue Jacques Monod -91893 ORSAY Cedex
LORIA, Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 ,
