Particle-Imaging Techniques for Experimental Fluid Mechanics, Annual Review of Fluid Mechanics, vol.23, issue.1, pp.261-304, 1991. ,
DOI : 10.1146/annurev.fl.23.010191.001401
´ Etude d'une classe de fonctions splines vectorielles en vue de l'approximation d'un champ de vitesse. ApplicationàApplication`Applicationà la météorologie, 1993. ,
A vector spline approximation, Journal of Approximation Theory, vol.67, issue.1, pp.51-79, 1991. ,
DOI : 10.1016/0021-9045(91)90025-6
Wavelet methods in statistics: some recent developments and their applications, Statistics Surveys, vol.1, issue.0, pp.16-55, 2007. ,
DOI : 10.1214/07-SS014
URL : https://hal.archives-ouvertes.fr/hal-00853883
Mathematical problems in image processing, Applied Mathematical Sciences, vol.147, 2006. ,
Identification of velocity fields for geophysical fluids from a sequence of images, Experiments in Fluids, vol.28, issue.1, 2008. ,
DOI : 10.1007/s00348-010-0926-9
URL : https://hal.archives-ouvertes.fr/hal-00905015
Ridgelets: a key to higher-dimensional intermittency?, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.357, issue.1760, pp.2495-2509, 1999. ,
DOI : 10.1098/rsta.1999.0444
Fast Discrete Curvelet Transforms, Multiscale Modeling & Simulation, vol.5, issue.3, pp.861-899, 2006. ,
DOI : 10.1137/05064182X
New tight frames of curvelets and optimal representations of objects with piecewise C 2 singularities, Comm. Pure Appl. Math, vol.57, issue.2, pp.219-266, 2004. ,
A surprisingly effective nonadaptive representation for objects with edges, Curves and Surface Fitting, p.105, 2000. ,
Image processing and analysis, Society for Industrial and Applied Mathematics (SIAM), 2005. ,
Reconstruction of Wavelet Coefficients Using Total Variation Minimization, SIAM Journal on Scientific Computing, vol.24, issue.5, pp.1754-1767, 2003. ,
DOI : 10.1137/S1064827501397792
URL : https://hal.archives-ouvertes.fr/hal-00712152
Dynamcis of monopolar vortices on a topographic beta-plane, J. Fluid Mech, vol.456, pp.353-376, 2002. ,
The modules m1qn3 and n1qn3. version 2.0, 1995. ,
Coupling models and data : which possibilities for remotely-sensed images, Progress and Challenge of Research on Computing Science, pp.365-383, 2004. ,
URL : https://hal.archives-ouvertes.fr/inria-00527201
Estimation of a motien field on satellite images from a simplified ocean circulation model, ICIP International INRIA Conference on Image Processing, pp.1077-1080, 2006. ,
Assimilation de données Lagrangiennes pour la simulation numérique en hydraulique fluviale, 2007. ,
Determining optical flow, Artificial Intelligence, vol.17, issue.1-3, pp.185-203, 1981. ,
DOI : 10.1016/0004-3702(81)90024-2
Data Assimilation of Satellite Images Within an Oceanographic Circulation Model, 2006 IEEE International Conference on Acoustics Speed and Signal Processing Proceedings, 2006. ,
DOI : 10.1109/ICASSP.2006.1660330
URL : https://hal.archives-ouvertes.fr/inria-00604108
Fast and Stable Vector Spline Method for Fluid Apparent Motion Estimation, 2007 IEEE International Conference on Image Processing, pp.505-508, 2007. ,
DOI : 10.1109/ICIP.2007.4379203
URL : https://hal.archives-ouvertes.fr/inria-00603910
Analysis of the black sea surface currents retrieved from space imagery, Rapport du 38ème Congrès de la Commission Internationale pour l'Exploration Scientifique de la mer Méditerranée, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00627839
Variational algorithms for analysis and assimilation of meteorological observations : Theoretical aspects, pp.97-110, 1986. ,
A variational method for the resolution of a data assimilation problem in oceanography, Inverse Problems, vol.14, issue.4, pp.979-997, 1998. ,
DOI : 10.1088/0266-5611/14/4/014
Combined Curvelet Shrinkage and Nonlinear Anisotropic Diffusion, IEEE Transactions on Image Processing, vol.16, issue.9, pp.2198-2206, 2007. ,
DOI : 10.1109/TIP.2007.902333
Spatiotemporal structure extraction and denoising of geophysical fluid image sequences using 3d curvelet transforms, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00329599
A Wavelet Tour of Signal Processing, 1998. ,
Modélisation mathématique et assimilation de données lagrangiennes pour l'océanographie, 2005. ,
Variational Assimilation of Fluid Motion from Image Sequence, SIAM Journal on Imaging Sciences, vol.1, issue.4, 2008. ,
DOI : 10.1137/080713896
URL : https://hal.archives-ouvertes.fr/hal-00596149
Vector field regularization by gradient vector flow, 2008. ,
Motion estimation and vector splines, Proceedings of IEEE Conference on Computer Vision and Pattern Recognition CVPR-94, pp.939-942, 1994. ,
DOI : 10.1109/CVPR.1994.323929
Regularization of ill-posed problems, Dokl. Akad. Nauk SSSR, 1963. ,
Variational data analysis with control of the forecast bias. Tellus. Series A, Dynamic meteorology and oceanography, pp.177-188, 2004. ,
URL : https://hal.archives-ouvertes.fr/inria-00325592
Sea surface velocity from sea surface temperature image sequences, Journal of Geophysical Research, 2000. ,
