Abstract : In the Design By Contract (DBC) approach, programmers specify methods with pre and postconditions (also called contracts). Earlier work added protocols to the DBC approach to describe allowed method call sequences for classes. We extend this work to deal with a variant of generic classes and multithreaded classes. We present the semantical foundations of our extension. We describe a new technique to check that method contracts are correct w.r.t. to protocols. We show how to generate programs that must be proven to show that method contracts are correct w.r.t. to protocols. Because little support currently exists to help writing method contracts, our technique helps programmers to check their contracts early in the development process.
https://hal.inria.fr/inria-00334527 Contributor : Clément HurlinConnect in order to contact the contributor Submitted on : Tuesday, May 19, 2009 - 12:26:44 PM Last modification on : Friday, February 4, 2022 - 3:23:04 AM Long-term archiving on: : Saturday, November 26, 2016 - 9:41:58 AM
Clément Hurlin. Specifying and Checking Protocols of Multithreaded Classes. ACM Symposium on Applied Computing (SAC'09), ACM, Mar 2009, Honolulu, United States. pp.587--592, ⟨10.1145/1529282.1529407⟩. ⟨inria-00334527v3⟩
