Word segmentation of Vietnamese texts: a comparison of approaches - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
We present in this paper a comparison between three segmentation systems for the Vietnamese language. Indeed, the majority of Vietnamese words is built by semantic composition from about 7,000 syllables, that also have a meaning as isolated words. So the identification of word boundaries in a text is not a simple task, and ambiguities often appear. Beyond the presentation of the tested systems, we also propose a standard definition for word segmentation in Vietnamese, and introduce a reference corpus developed for the purpose of evaluating such a task. The results observed confirm that it can be relatively well treated by automatic means, although a solution needs to be found to take into account out-of-vocabulary words.
lrec2008final.pdf (85 Ko) Télécharger le fichier
inria-00334760 , version 1 (28-10-2008)
  • HAL Id : inria-00334760 , version 1
Quang Thang Dinh, Hong Phuong Le, Thi Minh Huyen Nguyen, Cam Tu Nguyen, Mathias Rossignol, et al.. Word segmentation of Vietnamese texts: a comparison of approaches. 6th international conference on Language Resources and Evaluation - LREC 2008, ELRA - European Language Resources Association, May 2008, Marrakech, Morocco. ⟨inria-00334760⟩
530 Consultations
686 Téléchargements
