Effective impedance boundary conditions for an inhomogeneous thin layer on a curved metallic surface, IEEE Transactions on Antennas and Propagation, vol.46, issue.5, pp.710-715, 1998. ,
DOI : 10.1109/8.668915
Properties of the Generalized Polarization Tensors, Multiscale Modeling & Simulation, vol.1, issue.2, pp.335-348, 2003. ,
DOI : 10.1137/S1540345902404551
Reconstruction of conductivity inhomogeneities of small diameter via boundary measurements, Inverse problems and spectral theory, pp.23-32, 2004. ,
DOI : 10.1090/conm/348/06311
Advanced Engineering Electromagnetics, 1989. ,
Asymptotic formulas for steady state voltage potentials in the presence of thin inhomogeneities. A??rigorous error analysis, Journal de Math??matiques Pures et Appliqu??es, vol.82, issue.10, pp.821277-1301, 2003. ,
DOI : 10.1016/S0021-7824(03)00081-3
Asymptotic formulas for steady state voltage potentials in the presence of conductivity imperfections of small area, Zeitschrift f??r angewandte Mathematik und Physik, vol.52, issue.4, pp.543-572, 2001. ,
DOI : 10.1007/PL00001561
A general representation formula for boundary voltage perturbations caused by internal conductivity inhomogeneities of low volume fraction, ESAIM: Mathematical Modelling and Numerical Analysis, vol.37, issue.1, pp.159-173, 2003. ,
DOI : 10.1051/m2an:2003014
Géométrie contemporaine. Méthodes et applications . I Géométrie des surfaces, des groupes de transformations et des champs. [Geometry of surfaces, groups of transformations and fields], 1982. ,
Modern geometry?methods and applications . Part I, volume 93 of Graduate Texts in Mathematics The geometry of surfaces, transformation groups, and fields, 1992. ,
DOI : 10.1007/978-1-4612-4474-5
A general environment for the treatment of discrete problems and its application to the finite element method, IEEE Transactions on Magnetics, vol.34, issue.5, pp.3395-3398, 1998. ,
DOI : 10.1109/20.717799
Effective boundary condition for acoustic and electromagnetic scattering thin layer, 1993. ,
Modeling assemblies of biological cells exposed to electric fields, IEEE Transactions on Biomedical Engineering, vol.45, issue.10, pp.1259-1271, 1998. ,
DOI : 10.1109/10.720204
Differential forms wih applications to the physical sciences, 1963. ,
Dielectric properties of tissues and biological materials: a critical review, CRC in Biomedical Engineering, vol.17, issue.1, pp.25-104, 1989. ,
Spectral geometry, Riemannian submersions , and the Gromov-Lawson conjecture, Studies in Advanced Mathematics. Chapman & Hall/CRC, 1999. ,
Straightforward derivation of boundary conditions on sheet simulating an anisotropic thin layer, Electronics Letters, vol.24, issue.11, pp.663-665, 1988. ,
DOI : 10.1049/el:19880449
Thin layers in electrical engineering-example of shell models in analysing eddy-currents by boundary and finite element methods, IEEE Transactions on Magnetics, vol.29, issue.2, pp.1450-1455, 1993. ,
DOI : 10.1109/20.250676
Transmembrane voltage induced on altered erythrocyte shapes exposed to RF fields, Bioelectromagnetics, vol.56, issue.8, pp.631-633, 2004. ,
DOI : 10.1002/bem.20065
Interactions between electromagnetic field and biological tissues: Questions, some answers and future trends, International Compumag Society Newsletter, vol.10, issue.2, pp.4-9, 2003. ,
Méthodes asymptotiques pour le calcul de champs, 5` eme Conférence Européenne sur les Méthodes Numériques en Electromagnétisme, pp.29-30, 2006. ,
Numerical Determination of Transmembrane Voltage Induced on Irregularly Shaped Cells, Annals of Biomedical Engineering, vol.32, issue.4, pp.642-652, 2006. ,
DOI : 10.1007/s10439-005-9076-2
Analysis of the influence of the cell geometry, orientation and cell proximity effects on the electric field distribution from direct RF exposure, Physics in Medicine and Biology, vol.46, issue.1, pp.213-225, 2001. ,
DOI : 10.1088/0031-9155/46/1/315
Electropermeabilization of cell membranes, Advanced Drug Delivery Reviews, vol.35, issue.1, pp.3-19, 1999. ,
DOI : 10.1016/S0169-409X(98)00060-X
Gap Junctional Intercellular Communication and Carcinogenesis, Carcinogenesis, vol.11, issue.7, pp.1051-1058, 1990. ,
DOI : 10.1007/978-3-642-83971-9_9
