Unbounded knapsack problem: Dynamic programming revisited, European Journal of Operational Research, vol.123, issue.2, pp.168-181, 2000. ,
DOI : 10.1016/S0377-2217(99)00265-9
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.41.2135
A New Knapsack Solution Approach by Integer Equivalent Aggregation and Consistency Determination, INFORMS Journal on Computing, vol.9, issue.1, pp.43-50, 1997. ,
DOI : 10.1287/ijoc.9.1.43
Efficient heuristics for the 0/1 multidimensional knapsack, ROADEF, pp.95-106, 2006. ,
Computational aspects of hard Knapsack problems, Nonlinear Analysis: Theory, Methods & Applications, vol.47, issue.8, pp.5547-5558, 2001. ,
DOI : 10.1016/S0362-546X(01)00658-7
A hard knapsack problem, Naval Research Logistics, vol.6, issue.1, pp.85-98, 1988. ,
DOI : 10.1002/1520-6750(198802)35:1<85::AID-NAV3220350108>3.0.CO;2-D
Integer Programming, 1972. ,
The Theory and Computation of Knapsack Functions, Operations Research, vol.14, issue.6, pp.1045-1074, 1966. ,
DOI : 10.1287/opre.14.6.1045
Dynamic Programming and Strong Bounds for the 0-1 Knapsack Problem, Management Science, vol.45, issue.3, pp.414-424, 1999. ,
DOI : 10.1287/mnsc.45.3.414
A Mixture of Dynamic Programming and Branch-and-Bound for the Subset-Sum Problem, Management Science, vol.30, issue.6, pp.765-771, 1984. ,
DOI : 10.1287/mnsc.30.6.765
Knapsack Problems: Algorithms and Computer Implementations, 1990. ,
Integer and Combinatorial Optimization, 1988. ,
DOI : 10.1002/9781118627372
URL : http://dx.doi.org/10.1016/s0898-1221(99)91259-2
Knapsack Problems, 2004. ,
A hybrid algorithm for the 0-1 knapsack problem, Methods of Oper. Res, vol.49, pp.277-293, 1985. ,
Unbounded Knapsack Problem: New Results, Workshop Algorithms and Experiments (ALEX98), pp.103-111, 1998. ,
Towards reduction of the class of intractable unbounded knapsack problem, 2004. ,
An exact algorithm for the unbounded knapsack problem with minimizing maximum processing time, Journal of Computer Science, vol.3, issue.3, pp.138-143, 2007. ,
On dominated terms in the general knapsack problem, Operations Research Letters, vol.21, issue.1, pp.31-37, 1997. ,
DOI : 10.1016/S0167-6377(97)00018-7
