Optimal sharing of bags of tasks in heterogeneous clusters, 15th ACM Symp. on Parallelism in Algorithms and Architectures (SPAA'03), pp.1-10, 2003. ,
Energy-efficient algorithms for flow time minimization, ACM Trans. Algorithms, vol.3, issue.4, p.49, 2007. ,
Determining optimal processor speeds for periodic real-time tasks with different power characteristics, Proceedings of the IEEE EuroMicro Conférence on Real-Time Systems, pp.225-232, 2001. ,
Dynamic speed scaling to manage energy and temperature, Proceedings. 45th Annual IEEE Symposium on, pp.520-529, 2004. ,
Power-aware scheduling for makespan and flow, SPAA '06: Proceedings of the eighteenth annual ACM symposium on Parallelism in algorithms and architectures, pp.190-196, 2006. ,
Energy-Efficient Processor System Design, 2001. ,
Grid Computing: Making The Global Infrastructure a Reality, chapter Parameter Sweeps on the Grid with APST, 2003. ,
Energy efficient online deadline scheduling, SODA '07: Proceedings of the eighteenth annual ACM-SIAM symposium on Discrete algorithms, pp.795-804, 2007. ,
Allocation cost minimization for periodic hard real-time tasks in energy-constrained dvs systems, ICCAD '06: Proceedings of the 2006 IEEE/ACM international conference on Computer-aided design, pp.255-260, 2006. ,
Energy-efficient real-time task scheduling with task rejection, DATE '07: Proceedings of the conference on Design, automation and test in Europe, pp.1629-1634, 2007. ,
DOI : 10.1109/date.2007.364535
Energy-efficient task partition for periodic real-time tasks on platforms with dual processing elements, International Conference on Parallel and Distributed Systems (ICPADS), 2008. ,
Performance-constrained distributed dvs scheduling for scientific applications on power-aware clusters, SC '05: Proceedings of the 2005 ACM/IEEE conference on Supercomputing, vol.34, 2005. ,
Distributed adaptive task allocation in heterogeneous computing environments to maximize throughput, International Parallel and Distributed Processing Symposium (IPDPS), 2004. ,
Adaptive allocation of independent tasks to maximize throughput, IEEE Trans. Parallel Distributed Systems, vol.18, issue.10, pp.1420-1435, 2007. ,
Profile-based optimization of power performance by using dynamic voltage scaling on a pc cluster, Parallel and Distributed Processing Symposium, p.340, 2006. ,
Multiprocessor synthesis for periodic hard real-time tasks under a given energy constraint, DATE '06: Proceedings of the conference on Design, automation and test in Europe, vol.3001, pp.1061-1066, 2006. ,
A near-optimal solution for the heterogeneous multi-processor single-level voltage setup problem. Parallel and Distributed Processing Symposium, IEEE International, pp.1-10, 2007. ,
Voltage scheduling problem for dynamically variable voltage processors, ISLPED '98: Proceedings of the 1998 international symposium on Low power electronics and design, pp.197-202, 1998. ,
Real-time task scheduling for a variable voltage processor, ISSS '99: Proceedings of the 12th international symposium on System synthesis, p.24, 1999. ,
Communication-aware scheduling on heterogeneous master-worker platforms, 2008. ,
URL : https://hal.archives-ouvertes.fr/tel-00530131
Energy efficient fixed-priority scheduling for real-time systems on variable voltage processors, Design Automation Conference, p.6706, 2001. ,
Multi-version scheduling in rechargeable energy-aware real-time systems, J. Embedded Comput, vol.1, issue.2, pp.271-283, 2005. ,
Temperature-aware microarchitecture: Modeling and implementation, ACM Trans. Archit. Code Optim, vol.1, issue.1, pp.94-125, 2004. ,
Communication-aware task scheduling and voltage selection for total systems energy minimization, ICCAD '03: Proceedings of the, 2003. ,
, IEEE/ACM international conference on Computer-aided design, vol.510, 2003.
Power-aware resource allocation for independent tasks in heterogeneous real-time systems, International Conference on Parallel and Distributed Systems, pp.341-348, 2002. ,
Energy minimization of real-time tasks on variable voltage processors with transition energy overhead, ASPDAC: Proceedings of the 2003 conference on Asia South Pacific design automation, pp.65-70, 2003. ,
Scheduling with dynamic voltage/speed adjustment using slack reclamation in multiprocessor real-time systems, IEEE Transactions on Parallel and Distributed Systems, vol.14, issue.7, pp.686-700, 2003. ,
, Parc Club Orsay Université -ZAC des Vignes 4, rue Jacques Monod -91893 ORSAY Cedex
LORIA, Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 ,
