Second-order analysis of optimal control problems with control and initial-final state constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Convex Analysis Année : 2010
This paper provides an analysis of Pontryagine minima satisfying a quadratic growth condition, for optimal control problems of ordinary differential equations with constraints on initial-final state, as well as control constraints satisfying the uniform positive linear independence condition.
RR-6707.pdf (406.49 Ko) Télécharger le fichier
inria-00335869 , version 1 (30-10-2008)
  • HAL Id : inria-00335869 , version 1
J. Frederic Bonnans, Nikolai P. Osmolovskii. Second-order analysis of optimal control problems with control and initial-final state constraints. Journal of Convex Analysis, 2010, 17 (3), pp.885-913. ⟨inria-00335869⟩
409 Consultations
252 Téléchargements
