A Model of Stimulus-Specific Neural Assemblies in the Insect Antennal Lobe - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue PLoS Computational Biology Année : 2008
It has been proposed that synchronized neural assemblies in the antennal lobe of insects encode the identity of olfactory stimuli. In response to an odor, some projection neurons exhibit synchronous firing, phase-locked to the oscillations of the field potential, whereas others do not. Experimental data indicate that neural synchronization and field oscillations are induced by fast GABAA-type inhibition, but it remains unclear how desynchronization occurs. We hypothesize that slow inhibition plays a key role in desynchronizing projection neurons. Because synaptic noise is believed to be the dominant factor that limits neuronal reliability, we consider a computational model of the antennal lobe in which a population of oscillatory neurons interact through unreliable GABAA and GABAB inhibitory synapses. From theoretical analysis and extensive computer simulations, we show that transmission failures at slow GABAB synapses make the neural response unpredictable. Depending on the balance between GABAA and GABAB inputs, particular neurons may either synchronize or desynchronize. These findings suggest a wiring scheme that triggers stimulus-specific synchronized assemblies. Inhibitory connections are set by Hebbian learning and selectively activated by stimulus patterns to form a spiking associative memory whose storage capacity is comparable to that of classical binary-coded models. We conclude that fast inhibition acts in concert with slow inhibition to reformat the glomerular input into odor-specific synchronized neural assemblies.
34016_20100916040043429_1.pdf (1.41 Mo) Télécharger le fichier
inria-00336099 , version 1 (30-05-2020)
Dominique Martinez, Noelia Montejo. A Model of Stimulus-Specific Neural Assemblies in the Insect Antennal Lobe. PLoS Computational Biology, 2008, 4 (8), pp.1-16. ⟨10.1371/journal.pcbi.1000139⟩. ⟨inria-00336099⟩
60 Consultations
41 Téléchargements
