M. D. Gunzburger, Introduction into mathematical aspects of flow control and optimization, in: Lecture series 1997-05 on inverse design and optimization methods, Von Kármán Institute for Fluid Dynamics, 1997.
M. D. Gunzburger, Adjoint Equation-Based Methods for Control Problems in Incompressible, Flow, Turbulence and Combustion, vol.65, issue.3/4, pp.249-272, 2000.
DOI : 10.1023/A:1011455900396
A. J. Booker, J. E. Dennis-jr, P. D. Frank, D. B. Serafini, V. Torczon et al., A rigorous framework for optimization of expensive functions by surrogates, Structural Optimization, vol.16, issue.1, pp.1-13, 1999.
DOI : 10.1007/BF01197708
A. C. Antoulas, Approximation of Large-Scale Dynamical Systems, SIAM, 2005.
K. Ito and S. S. Ravindran, A Reduced-Order Method for Simulation and Control of Fluid Flows, Journal of Computational Physics, vol.143, issue.2, pp.403-425, 1998.
DOI : 10.1006/jcph.1998.5943
J. L. Lumley, Atmospheric Turbulence and Wave Propagation. The structure of inhomogeneous turbulence, A, pp.166-178, 1967.
L. Sirovich, Turbulence and the dynamics of coherent structures, Quarterly of Applied Mathematics XLV, issue.3, pp.561-590, 1987.
K. E. Willcox, Reduced-order aerodynamic models for aeroelastic control of turbomachines, Massachusetts Institute of Technology, 2000.
J. Burkardt, M. D. Gunzburger, and H. Lee, Centroidal Voronoi Tessellation-Based Reduced-Order Modeling of Complex Systems, SIAM Journal on Scientific Computing, vol.28, issue.2, 2004.
DOI : 10.1137/5106482750342221x
C. W. Rowley, MODEL REDUCTION FOR FLUIDS, USING BALANCED PROPER ORTHOGONAL DECOMPOSITION, International Journal of Bifurcation and Chaos, vol.15, issue.03, pp.997-1013, 2005.
DOI : 10.1142/S0218127405012429
X. Ma and G. E. Karniadakis, A low-dimensional model for simulating threedimensional cylinder flow, J. Fluid Mech, vol.458, pp.181-190, 2002.
B. R. Noack, K. Afanasiev, M. Morzy´nskimorzy´nski, G. Tadmor, and F. Thiele, A hierarchy of low-dimensional models for the transient and post-transient cylinder wake, Journal of Fluid Mechanics, vol.497, pp.335-363, 2003.
DOI : 10.1017/S0022112003006694
B. R. Noack, G. Tadmor, and M. Morzy´nskimorzy´nski, Low-Dimensional Models for Feedback Flow Control. Part I: Empirical Galerkin Models, 2nd AIAA Flow Control Conference, 2004.
DOI : 10.2514/6.2004-2408
M. Bergmann, L. Cordier, and J. Brancher, Optimal rotary control of the cylinder wake using POD Reduced Order Model, Phys. Fluids, vol.17, issue.097101, pp.1-21, 2005.
URL : https://hal.archives-ouvertes.fr/inria-00338850
W. R. Graham, J. Peraire, and K. T. Tang, Optimal control of vortex shedding using low-order models. Part I?open-loop model development, International Journal for Numerical Methods in Engineering, vol.111, issue.224, pp.945-972, 1999.
DOI : 10.1002/(SICI)1097-0207(19990310)44:7<945::AID-NME537>3.0.CO;2-F
S. S. Ravindran, Reduced-order adaptive controllers for fluid flows using POD, Journal of Scientific Computing, vol.15, issue.4, pp.457-478, 2000.
DOI : 10.1023/A:1011184714898
S. S. Ravindran, Adaptive Reduced-Order Controllers for a Thermal Flow System, SIAM Journal on Scientific Computing, vol.23, issue.6, pp.1925-1943, 2002.
M. Hinze and S. Volkwein, Proper Orthogonal Decomposition Surrogate Models for Nonlinear Dynamical Systems: Error Estimates and Suboptimal Control, 2004.
DOI : 10.1007/3-540-27909-1_10
C. H. Williamson, Vortex Dynamics in the Cylinder Wake, Annual Review of Fluid Mechanics, vol.28, issue.1, pp.477-539, 1996.
DOI : 10.1146/annurev.fl.28.010196.002401
P. T. Tokumaru and P. E. Dimotakis, Rotary oscillation control of a cylinder wake, Journal of Fluid Mechanics, vol.182, issue.-1, pp.77-90, 1991.
DOI : 10.1017/S0022112088001570
X. Lu and J. Sato, A NUMERICAL STUDY OF FLOW PAST A ROTATIONALLY OSCILLATING CIRCULAR CYLINDER, Journal of Fluids and Structures, vol.10, issue.8, pp.829-849, 1996.
DOI : 10.1006/jfls.1996.0055
M. H. Chou, Synchronization of vortex shedding from a cylinder under rotary oscillation, Computers & Fluids, vol.26, issue.8, pp.755-774, 1997.
DOI : 10.1016/S0045-7930(97)00028-5
S. J. Baek and H. J. Sung, Numerical simulation of the flow behind a rotary oscillating circular cylinder, Physics of Fluids, vol.10, issue.4, pp.869-876, 1998.
DOI : 10.1063/1.869610
F. M. Mahfouz and H. M. Badr, Flow Structure in the Wake of a Rotationally Oscillating Cylinder, Journal of Fluids Engineering, vol.122, issue.2, pp.290-301, 2000.
DOI : 10.1115/1.483257
S. Baek and H. J. Sung, Quasi-periodicity in the wake of a rotationally oscillating cylinder, Journal of Fluid Mechanics, vol.408, pp.275-300, 2000.
DOI : 10.1017/S0022112099007855
M. Cheng, Y. T. Chew, and S. C. Luo, NUMERICAL INVESTIGATION OF A ROTATIONALLY OSCILLATING CYLINDER IN MEAN FLOW, Journal of Fluids and Structures, vol.15, issue.7, pp.981-1007, 2001.
DOI : 10.1006/jfls.2001.0387
M. Cheng, G. R. Liu, and K. Y. Lam, Numerical simulation of flow past a rotationally oscillating cylinder, Computers & Fluids, vol.30, issue.3, pp.365-392, 2001.
DOI : 10.1016/S0045-7930(00)00012-8
S. Choi, H. Choi, and S. Kang, Characteristics of flow over a rotationally oscillating cylinder at low Reynolds number, Physics of Fluids, vol.14, issue.8, pp.2767-2777, 2002.
DOI : 10.1063/1.1491251
B. Protas and J. Wesfreid, Drag force in the open-loop control of the cylinder wake in the laminar regime, Physics of Fluids, vol.14, issue.2, pp.810-826, 2002.
DOI : 10.1063/1.1432695
N. Fujisawa, K. Ikemoto, and K. Nagaja, VORTEX SHEDDING RESONANCE FROM A ROTATIONALLY OSCILLATING CYLINDER, Journal of Fluids and Structures, vol.12, issue.8, pp.1041-1053, 1998.
DOI : 10.1006/jfls.1998.0178
N. Fujisawa, Y. Kawaji, and K. Ikemoto, FEEDBACK CONTROL OF VORTEX SHEDDING FROM A CIRCULAR CYLINDER BY ROTATIONAL OSCILLATIONS, Journal of Fluids and Structures, vol.15, issue.1, pp.23-37, 2001.
DOI : 10.1006/jfls.2000.0323
S. Goujon-durand, J. Wesfreid, and P. Jenffer, Contrôle actif du sillage autour d'un cylindre oscillant, 15th French Congress of Mechanics, 2001.
B. Thiria, S. Goujon-durand, and J. Wesfreid, The wake of a cylinder performing rotary oscillations, Journal of Fluid Mechanics, vol.560
DOI : 10.1017/S0022112006000656
F. Abergel and R. Temam, On some control problems in fluid mechanics, Theoretical and Computational Fluid Dynamics, vol.10, issue.4, 1990.
DOI : 10.1007/BF00271794
T. R. Bewley, Flow control: new challenges for a new Renaissance, Progress in Aerospace Sciences, vol.37, issue.1, pp.21-58, 2001.
DOI : 10.1016/S0376-0421(00)00016-6
T. R. Bewley, The emerging roles of model-based control theory in fluid mechanics, in: Advances in Turbulence IX, 2002.
J. He, R. Glowinski, R. Metcalfe, A. Nordlander, and J. Périaux, Active control and drag optimization for flow past a circular cylinder. Part 1. Oscillatory cylinder rotation, J. Comp. Phys, pp.163-83, 2000.
C. Homescu, I. M. Navon, and Z. Li, Suppression of vortex shedding for flow around a circular cylinder using optimal control, International Journal for Numerical Methods in Fluids, vol.11, issue.1, pp.43-69, 2002.
DOI : 10.1002/fld.203
B. Protas and A. Styczek, Optimal rotary control of the cylinder wake in the laminar regime, Physics of Fluids, vol.14, issue.7, pp.2073-2087, 2002.
DOI : 10.1063/1.1476671
T. R. Bewley, P. Moin, and R. Temam, DNS-based predictive control of turbulence: an optimal benchmark for feedback algorithms, Journal of Fluid Mechanics, vol.447, pp.179-225, 2001.
DOI : 10.1017/S0022112001005821
Y. Chang, Approximate models for optimal control of turbulent channel flow, Rice university, 2000.
M. Wei and J. B. Freund, A noise-controlled free shear flow, Journal of Fluid Mechanics, vol.546, issue.-1, pp.123-152, 2006.
DOI : 10.1017/S0022112005007093
N. Alexandrov, J. E. Dennis-jr, R. M. Lewis, and V. Torczon, A trust-region framework for managing the use of approximation models in optimization, Structural Optimization, vol.12, issue.1, pp.97-50
DOI : 10.1007/BF01197433
M. Bergmann, L. Cordier, and J. Brancher, On the power used to control the circular cylinder drag by rotary oscillations, Phys. Fluids, vol.18, issue.088103, pp.1-4, 2006.
B. R. Noack and H. Eckelmann, A global stability analysis of the steady and periodic cylinder wake, Journal of Fluid Mechanics, vol.74, issue.-1, pp.297-330, 1994.
DOI : 10.1016/0167-2789(92)90021-E
D. Barkley and R. D. Henderson, Three-dimensional Floquet stability analysis of the wake of a circular cylinder, Journal of Fluid Mechanics, vol.199, issue.-1, pp.215-241, 1996.
DOI : 10.1016/0021-9991(91)90007-8
L. Cordier and M. Bergmann, Proper Orthogonal Decomposition: an overview, in: Lecture series 2002-04 on post-processing of experimental and numerical data, Von Kármán Institute for Fluid Dynamics, 2002.
W. R. Graham, J. Peraire, and K. T. Tang, Optimal control of vortex shedding using low-order models. Part II?model-based control, International Journal for Numerical Methods in Engineering, vol.44, issue.7, pp.973-990, 1999.
DOI : 10.1002/(SICI)1097-0207(19990310)44:7<973::AID-NME538>3.0.CO;2-F
J. Nocedal and S. J. Wright, Numerical Optimization, Springer series in operations research, 1999.
M. Bergmann and L. Cordier, Optimal flow control of the cylinder wake by POD Reduced Order Models and Trust-Region methods, 2008.
E. Arian, M. Fahl, and E. W. Sachs, Trust-Region Proper Orthogonal Decomposition for Flow Control
A. R. Conn, N. I. Gould, and P. L. Toint, Trust-region methods, 2000.
DOI : 10.1137/1.9780898719857
P. L. Toint, Global Convergence of a a of Trust-Region Methods for Nonconvex Minimization in Hilbert Space, IMA Journal of Numerical Analysis, vol.8, issue.2, pp.231-252, 1988.
DOI : 10.1093/imanum/8.2.231
M. Bergmann, Optimisation aérodynamique par réduction de modèle POD et contrôle optimal Application au sillage laminaire d'un cylindre circulaire, 2004.
B. R. Noack, P. Papas, and P. A. Monkewitz, The need for a pressure-term representation in empirical Galerkin models of incompressible shear flows, Journal of Fluid Mechanics, vol.523, pp.339-365, 2005.
DOI : 10.1017/S0022112004002149
B. Galletti, C. Bruneau, L. Zannetti, and A. , Low-order modelling of laminar flow regimes past a confined square cylinder, Journal of Fluid Mechanics, vol.503, pp.161-170, 2004.
DOI : 10.1017/S0022112004007906
C. Kasnakoglu, Reduced order modeling, nonlinear analysis and control methods for flow control problems, 2007.
H. Gunes, S. Sirisup, and G. E. Karniadakis, Gappy data: To Krig or not to Krig?, Journal of Computational Physics, vol.212, issue.1, pp.358-382, 2006.
DOI : 10.1016/j.jcp.2005.06.023
URL : http://www.dtic.mil/get-tr-doc/pdf?AD=ADA459195
K. Willcox, Unsteady flow sensing and estimation via the gappy proper orthogonal decomposition, Computers & Fluids, vol.35, issue.2, pp.208-226, 2006.
DOI : 10.1016/j.compfluid.2004.11.006
D. Rempfer and H. F. , Evolution of three-dimensional coherent structures in a flat-plate boundary layer, Journal of Fluid Mechanics, vol.104, issue.-1, pp.351-375, 1994.
DOI : 10.1063/1.857573
M. Couplet, C. Basdevant, and P. Sagaut, Calibrated reduced-order POD-Galerkin system for fluid flow modelling, Journal of Computational Physics, vol.207, issue.1, pp.192-220, 2005.
DOI : 10.1016/j.jcp.2005.01.008
B. Galletti, A. Bottaro, C. Bruneau, and A. Iollo, Accurate model reduction of transient and forced wakes, European Journal of Mechanics - B/Fluids, vol.26, issue.3, pp.354-366, 2007.
DOI : 10.1016/j.euromechflu.2006.09.004
URL : https://hal.archives-ouvertes.fr/hal-00262163
J. Favier, L. Cordier, and A. Kourta, Accurate POD Reduced-Order Models of separated flows, Phys. Fluids
URL : https://hal.archives-ouvertes.fr/hal-00175335
A. E. Deane, I. G. Kevrekidis, G. E. Karniadakis, and S. A. Orszag, Low???dimensional models for complex geometry flows: Application to grooved channels and circular cylinders, Physics of Fluids A: Fluid Dynamics, vol.3, issue.10, pp.2337-2354, 1991.
DOI : 10.1063/1.857881
K. Afanasiev and M. Hinze, Adaptive control of a wake flow using Proper Orthogonal Decomposition, in: Shape Optimization and Optimal Design, Lecture Notes in Pure and Applied Mathematics, vol.216, 2001.
B. Protas and J. Wesfreid, On the relation between the global modes and the spectra of drag and lift in periodic wake flows, Comptes Rendus M??canique, vol.331, issue.1, pp.49-54, 2003.
DOI : 10.1016/S1631-0721(02)00018-9
C. Homescu, L. R. Petzold, and R. Serban, Error Estimation for Reduced Order Models of Dynamical Systems, 2003.
