Logoot: a P2P collaborative editing system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Stéphane Weiss
  • Fonction : Auteur
  • PersonId : 839033
Pascal Urso
  • Fonction : Auteur
  • PersonId : 830668
Pascal Molli
Massive collaborative editing becomes a reality through leading projects such as the Wikipedia. Such massive collaboration is currently supported with costly central service. To avoid such costs, we aim to provide a peer-to-peer collaborative editing system. Existing approaches that propose distributed collaborative distributed either do not scale in term of users number or in term of editions number. We present the Logoot approach that scales in these both dimensions while ensuring causality, consistency and intention criteria. We evaluate the Logoot approach and compare it to others with a corpus of all the editions applied on a set of the most edited and biggest page of the Wikipedia.
RR-6713.pdf (268.82 Ko) Télécharger le fichier
inria-00336191 , version 1 (03-11-2008)
inria-00336191 , version 2 (04-11-2008)
inria-00336191 , version 3 (10-12-2008)
  • HAL Id : inria-00336191 , version 2
Stéphane Weiss, Pascal Urso, Pascal Molli. Logoot: a P2P collaborative editing system. [Research Report] RR-6713, 2008, pp.13. ⟨inria-00336191v2⟩
Collections
INRIA-RRRT
583 Consultations
3640 Téléchargements
