Improved approximate response time bounds for static-priority tasks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
We consider sporadic tasks with static priorities and constrained deadlines to be executed upon a uniprocessor platform. Pseudo-polynomial time algorithms are known for computing worst-case response times for this task model. Some applications require to evaluate efficiently upper bounds of response times. For this purpose, we propose parametric algorithms that allow to make a tradeoff between quality of results and computational effort according to an input accuracy parameter. In this paper, we present a parametric polynomial-time algorithm for computing upper bounds of worst-case response times, that is based on an improved FPTAS (Fully Polynomial Time Approximation Scheme). Then, we show that our bound does not achieve constant error bound in comparison with the exact worstcase response time. However, using the resource augmentation technique, we obtain a performance guarantee that allows to define a compromise between our response-time bound and processor capacity requirements. The algorithm average behavior is then analyzed through numerical experimentations.
nguyen.pdf (541.17 Ko) Télécharger le fichier
inria-00336498 , version 1 (04-11-2008)
  • HAL Id : inria-00336498 , version 1
Thi Huyen Chau Nguyen, Pascal Richard, Enrico Bini. Improved approximate response time bounds for static-priority tasks. 16th International Conference on Real-Time and Network Systems (RTNS 2008), Isabelle Puaut, Oct 2008, Rennes, France. ⟨inria-00336498⟩
109 Consultations
314 Téléchargements
