New interface
Conference papers
A Parallel Incremental Learning Algorithm for Neural Networks with Fault Tolerance
Abstract : This paper presents a parallel and fault tolerant version of an incremental learning algorithm for feed-forward neural networks used as function approximators. It has been shown in previous works that our incremental algorithm builds networks of reduced size while providing high quality approximations for real data sets. However, for very large sets, the use of our learning process on a single machine may be quite long and even sometimes impossible, due to memory limitations. The parallel algorithm presented in this paper is usable in any parallel system, and in particular, with large dynamical systems such as clusters and grids in which faults may occur. Finally, the quality and performances (without and with faults) of that algorithm are experimentally evaluated.
Complete list of metadata
https://hal.inria.fr/inria-00336521
Contributor : Sylvain Contassot-Vivier Connect in order to contact the contributor
Submitted on : Tuesday, November 4, 2008 - 1:23:31 PM
Last modification on : Friday, January 21, 2022 - 3:09:38 AM
Identifiers
  • HAL Id : inria-00336521, version 1
Citation
Jacques Bahi, Sylvain Contassot-Vivier, Marc Sauget, Aurélien Vasseur. A Parallel Incremental Learning Algorithm for Neural Networks with Fault Tolerance. 8th International Meeting on High Performance Computing for Computational Science, VECPAR'08, Jun 2008, Toulouse, France. pp.502--515. ⟨inria-00336521⟩
Share
Metrics
Record views
144
