A semi-Lagrangian contouring method for fluid simulation, ACM Transactions on Graphics, vol.25, issue.1, pp.19-38, 2006. ,
DOI : 10.1145/1122501.1122503
CONREC: A contouring subroutine Byte: The Small Systems Journal, pp.143-150, 1987. ,
Mapping computational concepts to gpus, In GPU Gems, vol.2, issue.32, pp.509-519, 2005. ,
Real-time simulation and rendering of 3d fluids, GPU Gems 3, pp.633-673, 2007. ,
Fast hierarchical 3d distance transforms on the gpu, EG'07 Short Papers, pp.93-96, 2007. ,
Real-time particle level sets with applications to flow visualization, 2007. ,
A fast and accurate semi-Lagrangian particle level set method, Computers & Structures, vol.83, issue.6-7, pp.6-7479, 2005. ,
DOI : 10.1016/j.compstruc.2004.04.024
Animation and rendering of complex water surfaces, ACM Trans. Graph, vol.21, issue.3, pp.736-744, 2002. ,
Practical animation of liquids, Proceedings of the 28th annual conference on Computer graphics and interactive techniques , SIGGRAPH '01, pp.23-30, 2001. ,
DOI : 10.1145/383259.383261
Real-Time Ray-Casting and Advanced Shading of Discrete Isosurfaces, Computer Graphics Forum, vol.5, issue.3, pp.303-312, 2005. ,
DOI : 10.1111/j.1467-8659.2005.00855.x
Smoothed particle hydrodynamics on gpus, Proc. CGI '07, 2007. ,
Fast fluid dynamics simulation on the GPU, ACM SIGGRAPH 2005 Courses on , SIGGRAPH '05, pp.637-666, 2004. ,
DOI : 10.1145/1198555.1198790
Mapping computational concepts to GPUs, ACM SIGGRAPH 2005 Courses on , SIGGRAPH '05, pp.493-508, 2005. ,
DOI : 10.1145/1198555.1198768
A Lagrangian particle level set method, Journal of Computational Physics, vol.210, issue.1, pp.342-367, 2005. ,
DOI : 10.1016/j.jcp.2005.04.013
Hierarchical RLE level set, ACM Transactions on Graphics, vol.25, issue.1, pp.151-175, 2006. ,
DOI : 10.1145/1122501.1122508
Dynamic particle coupling for gpubased fluid simulation, Proc. 18th Symposium on Simulation Technique, pp.722-727, 2005. ,
Interactive deformation and visualization of level set surfaces using graphics hardware, IEEE Transactions on Ultrasonics, Ferroelectrics and Frequency Control, 2003. ,
DOI : 10.1109/VISUAL.2003.1250357
Simulating water and smoke with an octree data structure, ACM Transactions on Graphics, vol.23, issue.3, pp.457-462, 2004. ,
DOI : 10.1145/1015706.1015745
Textured Liquids based on the Marker Level Set, Computer Graphics Forum, vol.2, issue.3, pp.457-466, 2007. ,
DOI : 10.1006/jcph.1994.1155
The marker level set method: a new approach for computing accurate interfacial dynamics, 2007. ,
A particle level set library, 2006. ,
Level set surface editing operators, ACM Trans. Graph, vol.21, issue.3, pp.330-338, 2002. ,
Level Set Methods and Dynamic Implicit Surfaces, 2003. ,
Fronts propagating with curvature-dependent speed: Algorithms based on Hamilton-Jacobi formulations, Journal of Computational Physics, vol.79, issue.1, pp.12-49, 1988. ,
DOI : 10.1016/0021-9991(88)90002-2
A Survey of General-Purpose Computation on Graphics Hardware, Computer Graphics Forum, vol.7, issue.4, pp.80-113, 2007. ,
DOI : 10.1016/j.rti.2005.04.002
A PDE-Based Fast Local Level Set Method, Journal of Computational Physics, vol.155, issue.2, pp.410-438, 1999. ,
DOI : 10.1006/jcph.1999.6345
Level set segmentation in graphics hardware, Proceedings 2001 International Conference on Image Processing (Cat. No.01CH37205), pp.1103-1106, 2001. ,
DOI : 10.1109/ICIP.2001.958320
A Remark on Computing Distance Functions, Journal of Computational Physics, vol.163, issue.1, pp.51-67, 2001. ,
DOI : 10.1006/jcph.2000.6553
An Unconditionally Stable MacCormack Method, Journal of Scientific Computing, vol.14, issue.9, 2007. ,
DOI : 10.1007/s10915-007-9166-4
Level Set Methods and Fast Marching Methods: Evolving Interfaces in Computational Geometry, Fluid Mechanics, Computer Vision, and Materials Science, 1999. ,
Fast volume segmentation with simultaneous visualization using programmable graphics hardware, IEEE Transactions on Ultrasonics, Ferroelectrics and Frequency Control, p.23, 2003. ,
DOI : 10.1109/VISUAL.2003.1250369
Stable fluids, Proceedings of the 26th annual conference on Computer graphics and interactive techniques , SIGGRAPH '99, pp.121-128, 1999. ,
DOI : 10.1145/311535.311548
A second order coupled level set and volume-of-fluid method for computing growth and collapse of vapor bubbles, Journal of Computational Physics, vol.187, issue.1, pp.110-136, 2003. ,
DOI : 10.1016/S0021-9991(03)00087-1
Gpu-based particle simulation with inter-collisions. The Visual Computer, pp.9-11851, 2007. ,
A level-set method for flow visualization, Proceedings Visualization 2000. VIS 2000 (Cat. No.00CH37145), 2000. ,
DOI : 10.1109/VISUAL.2000.885688
An improved study of real-time fluid simulation on GPU, Computer Animation and Virtual Worlds, vol.15, issue.34, pp.3-4139, 2004. ,
DOI : 10.1002/cav.16
Gpubased data compaction using histopyramids, Proc. VMV '06, pp.137-141, 2006. ,
