Artificial Ontogeny for Truss Structure Design
This paper introduces an approach based on Artificial Embryogeny for truss design to address the problem of finding the best truss structure for a given loading. In this setup, the basic idea is to optimize the size and length of beams in a truss through the actions of a set of cells that are distributed over the very truss structure. Given information at the mechanical level (beam strain), each cell controller is able to modify the local truss structure (beam size and length) during a developmental process. The advantage of such a method relies on the idea that a template cell controller is duplicated over all cells, keeping the optimization search space very low, while each cell may act in a different manner depending on local information. This approach is demonstrated on a classical benchmark, the cantilever: resulting organisms are shown to provide very interesting and unique properties regarding reuse of optimized genotypes in noisy or higher-dimension settings.
