Wavelet approximations of the Hamiltonian operator and computation of related energies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2008
Multiresolution analysis in Quantum Chemistry provide efficient computational methods. In this article, we propose several representations of the Hamiltonian operator arising from the Density Functional Theory, based on orthogonal and interpolating scaling function bases. These high order approximations allows to compute the potential and kinetic energies with a linear complexity. Finally numerical examples show the accuracy of the method.
article.pdf (516.62 Ko) Télécharger le fichier
inria-00337464 , version 1 (07-11-2008)
  • HAL Id : inria-00337464 , version 1
Claire Chauvin, Valérie Perrier. Wavelet approximations of the Hamiltonian operator and computation of related energies. 2008. ⟨inria-00337464⟩
88 Consultations
82 Téléchargements
