Stochastic Downscaling Method: Application to Wind Refinement - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Stochastic Environmental Research and Risk Assessment Année : 2009
In this article, we propose a new stochastic downscaling method: provided a numerical prediction of wind at large scale, we aim to improve the approximation at small scales thanks to a local stochastic model. We first recall the framework of a Lagrangian stochastic model borrowed from S.B. Pope. Then, we adapt it to our meteorological framework, both from the theoretical and numerical viewpoints. Finally, we present some promising numerical results corresponding to the simulation of wind over the Mediterranean Sea.
Serra08.pdf (306.29 Ko) Télécharger le fichier
inria-00337526 , version 1 (07-11-2008)
Frédéric Bernardin, Mireille Bossy, Claire Chauvin, Philippe Drobinski, Antoine Rousseau, et al.. Stochastic Downscaling Method: Application to Wind Refinement. Stochastic Environmental Research and Risk Assessment, 2009, 23 (6), pp.851-859. ⟨10.1007/s00477-008-0276-9⟩. ⟨inria-00337526⟩
895 Consultations
404 Téléchargements
