Equilibrium Temperature of an Unheated Icing Surface as a Function of Air Speed, Journal of the Aeronautical Sciences, vol.20, issue.1, pp.29-42, 1953. ,
DOI : 10.2514/8.2520
Numerical simulation of airfoil ice accretion, 21st Aerospace Sciences Meeting, pp.83-0112, 1983. ,
DOI : 10.2514/6.1983-112
Users Manual for the NASA Lewis Ice Accretion Prediction Code (LEWICE), 1990. ,
ONERA Three-Dimensional Icing Model, AIAA Journal, vol.33, issue.6, pp.1038-1045, 1995. ,
Ice Accretion on Aircraft Wings with Thermodynamic Effects, 1994. ,
Ice accretion calculations for a commercial transport using the LEWICE3D, ICEGRID3D and CMARC programs, 37th Aerospace Sciences Meeting and Exhibit, 1999. ,
DOI : 10.2514/6.1999-250
A second order finite element method for the solution of the transonic Euler and Navier-Stokes equations, International Journal for Numerical Methods in Fluids, vol.5, issue.8-9, pp.671-693, 1995. ,
DOI : 10.1002/fld.1650200802
A finite element method study of Eulerian droplets impingement models, International Journal for Numerical Methods in Fluids, vol.3, issue.4, pp.429-449, 1999. ,
DOI : 10.1002/(SICI)1097-0363(19990228)29:4<429::AID-FLD795>3.0.CO;2-F
FENSAP-ICE`s Three-Dimensional In-flight Ice Accretion Module, Journal of Aircraft, vol.40, issue.2, pp.239-247, 2003. ,
CHT3D - FENSAP-ICE conjugate heat transfer computations with droplet impingement and runback effects, 40th AIAA Aerospace Sciences Meeting & Exhibit, pp.2002-0386, 2002. ,
DOI : 10.2514/6.2002-386
A one-equation turbulence model for aerodynamic flows, 30th Aerospace Sciences Meeting and Exhibit, 1992. ,
DOI : 10.2514/6.1992-439
Trends in turbulence treatments, Fluids 2000 Conference and Exhibit, 2000. ,
DOI : 10.2514/6.2000-2306
Roughness Implementation in FENSAP-ICE: Model Calibration and Influence on Ice Shapes, Journal of Aircraft, vol.40, issue.6, pp.1212-1215, 2003. ,
DOI : 10.2514/1.2318
A PDE-Based 3D Approach for In-Flight Ice Accretion, 2003. ,
Certifiable Computational Fluid Dynamics Through Mesh Optimization, Special Issue on Credible Computational Fluid Dynamics Simulation AIAA Journal, vol.36, issue.5, pp.703-711, 1998. ,
DOI : 10.2514/3.13883
The consistent Galerkin FEM for computing derived boundary quantities in thermal and or fluids problems, International Journal for Numerical Methods in Fluids, vol.2, issue.4, pp.371-394, 1987. ,
DOI : 10.1002/fld.1650070406
A Theoretical Framework for Petrov-Galerkin Methods with Discontinuous Weighting Functions: Application to the Streamline-Upwind Procedure " , Finite Element in Fluids, 1982. ,
Development of a Shallow-Water Icing Model in FENSAP-ICE, Journal of Aircraft, vol.37, issue.4, pp.640-646, 2000. ,
DOI : 10.2514/2.2646
Validation Results for LEWICE 2, 1999. ,
DOI : 10.2514/6.2005-1243
Ice Accretion Simulation Evaluation Test, NATO RTO Technical Report, vol.38, 2001. ,
Anisotropic 3D Mesh Adaptation on Unstructured Hybrid Meshes, pp.2002-0859, 2002. ,
Anisotropic mesh adaptation: towards user-independent, mesh-independent and solver-independent CFD. Part III. Unstructured meshes, International Journal for Numerical Methods in Fluids, vol.1, issue.8, pp.675-702, 2002. ,
DOI : 10.1002/fld.357
Verification and Validation in Computational Science and Engineering, Hermosa publishers, 1998. ,
An Experimental Method for Measuring Water Droplet Impingement Efficiency on Two-and Three-Dimensional Bodies, 1989. ,
Collection Efficiency and Ice Accretion Calculations for a Boeing 737-300 Inlet, SAE Technical Paper Series, 1996. ,
DOI : 10.4271/965570
Design of Ice Protection Systems and Icing Certification Through Cost-Effective Use of CFD, pp.2002-0382, 2002. ,
