Index calculus for abelian varieties of small dimension and the elliptic curve discrete logarithm problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Symbolic Computation Année : 2009
We propose an index calculus algorithm for the discrete logarithm problem on general abelian varieties of small dimension. The main difference with the previous approaches is that we do not make use of any embedding into the Jacobian of a well-suited curve. We apply this algorithm to the Weil restriction of elliptic curves and hyperelliptic curves over small degree extension fields. In particular, our attack can solve an elliptic curve discrete logarithm problem defined over GF(q^3) in heuristic asymptotic running time O~(q^(4/3)); and an elliptic problem over GF(q^4) or a genus 2 problem over GF(q^2) in heuristic asymptotic running time O~(q^(3/2)).
indexcalc.pdf (201.2 Ko) Télécharger le fichier
inria-00337631 , version 1 (07-11-2008)
Pierrick Gaudry. Index calculus for abelian varieties of small dimension and the elliptic curve discrete logarithm problem. Journal of Symbolic Computation, 2009, 44 (12), pp.1690-1702. ⟨10.1016/j.jsc.2008.08.005⟩. ⟨inria-00337631⟩
380 Consultations
986 Téléchargements
