Error Reducing Sampling in Reinforcement Learning
In reinforcement learning, an agent collects information interacting with an environment and uses it to derive a behavior. This paper focuses on efficient sampling; that is, the problem of choosing the interaction samples so that the corresponding behavior tends quickly to the optimal behavior. Our main result is a sensitivity analysis relating the choice of sampling any state-action pair to the decrease of an error bound on the optimal solution. We derive two new model-based algorithms. Simulations demonstrate a quicker convergence (in the sense of the number of samples) of the value function to the real optimal value function.
Intelligence artificielle [cs.AI]
