Anti-Pattern Matching Modulo - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Negation is intrinsic to human thinking and most of the time when searching for something, we base our patterns on both positive and negative conditions. In a recent work, the notion of term was extended to the one of anti-term, i.e. terms that may contain complement symbols. Here we generalize the syntactic anti-pattern matching to anti-pattern matching modulo an arbitrary equational theory E, and we study the specific and practically very useful case of associativity, possibly with a unity (AU). To this end, based on the syntacticness of associativity, we present a rule-based associative matching algorithm, and we extend it to AU. This algorithm is then used to solve AU anti-pattern matching problems. This allows us to be generic enough so that for instance, the AllDiff standard predicate of constraint programming becomes simply expressible in this framework. AU anti-patterns are implemented in the Tom language and we show some examples of their usage.
KirchnerKM-LATA2008.pdf (189.03 Ko) Télécharger le fichier
inria-00337722 , version 1 (07-11-2008)
Claude Kirchner, Radu Kopetz, Pierre-Etienne Moreau. Anti-Pattern Matching Modulo. Second International Conference on Language and Automata Theory and Applications - LATA 2008, Mar 2008, Tarragone, Italy. pp.275-286, ⟨10.1007/978-3-540-88282-4_26⟩. ⟨inria-00337722⟩
85 Consultations
155 Téléchargements
