Oracle-Assisted Static Diffie-Hellman Is Easier Than Discrete Logarithms
This paper extends Joux-Naccache-Thomé's e-th root algorithm to the static Diffie-Hellman problem (sdhp). The new algorithm can be adapted to diverse finite fields by customizing it with an nfs-like core or an ffs-like core. In both cases, after a number of sdhp oracle queries, the attacker builds-up the ability to solve new sdhp instances unknown before the query phase. While sub-exponential, the algorithm is still significantly faster than all currently known dlp and sdhp resolution methods. We explore the applicability of the technique to various cryptosystems. The attacks were implemented in F_{2^1025} and also in F_p, for a 516-bit p.
