Solist or How To Look For a Needle in a Haystack? A Lightweight Multi-Overlay Structure for Wireless Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In this paper, we consider sensor database systems. Sensors are attached to objects and queries on the objects are operated at the sensor network level. Although queries to such a system might be extremely complex, ensuring efficiently basic functionalities such as broadcast or anycast without any central element is not trivial. In this paper, we provide a suite of *-cast (anycast, $k$-cast, broadcast) functionalities in a fully decentralized manner. More specifically, we present the design and evaluation of \textsc{Solist}, a multi-layer structure for sensors, largely inspired from structured peer-to-peer systems providing such functionalities. The main goal of \textsc{Solist} is to limit the overall energy consumption. A type is associated to each sensor, and the \mbox{*-cast} functionalities are implemented at a type granularity regardless of the number of types and their distribution within the network. A typical use of such a system is sensor-based stock management. We evaluate \textsc{Solist} through simulations and show that \textsc{Solist} achieves a reasonable trade-off between performance and energy consumption.
busnel-solistHaystack.pdf (3.67 Mo) Télécharger le fichier
inria-00338128 , version 1 (11-11-2008)
  • HAL Id : inria-00338128 , version 1
Yann Busnel, Marin Bertier, Anne-Marie Kermarrec. Solist or How To Look For a Needle in a Haystack? A Lightweight Multi-Overlay Structure for Wireless Sensor Networks. IEEE WiMob '08, Oct 2008, Avignon, France. ⟨inria-00338128⟩
180 Consultations
272 Téléchargements
