Flow control, 1995. ,
DOI : 10.1007/978-1-4612-2526-3
Introduction into mathematical aspects of flow control and optimization. In: Lecture series 1997-05 on inverse design and optimization methods, Von Kármán Institute for Fluid Dynamics, 1997. ,
Proper Orthogonal Decomposition: an overview. In: Lecture series 2002-04 on post-processing of experimental and numerical data, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-00417819
Two typical applications of POD: coherent structures eduction and reduced order modelling In: Lecture series 2002-04 on post-processing of experimental and numerical data, 2002. ,
Optimal rotary control of the cylinder wake using POD Reduced Order Model, Phys. Fluids, vol.17, issue.097101, pp.1-21, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00338850
Trust-Region methods for flow control based on Reduced Order Modeling, 2000. ,
Vortex Dynamics in the Cylinder Wake, Annual Review of Fluid Mechanics, vol.28, issue.1, pp.477-539, 1996. ,
DOI : 10.1146/annurev.fl.28.010196.002401
Drag force in the open-loop control of the cylinder wake in the laminar regime, Physics of Fluids, vol.14, issue.2, pp.810-826, 2002. ,
DOI : 10.1063/1.1432695
Active control and drag optimization for flow past a circular cylinder. Part 1. Oscillatory cylinder rotation, J. Comp. Phys, pp.163-83, 2000. ,
Suppression of vortex shedding for flow around a circular cylinder using optimal control, International Journal for Numerical Methods in Fluids, vol.11, issue.1, pp.43-69, 2002. ,
DOI : 10.1002/fld.203
Control of the cylinder wake in the laminar regime by Trust-Region methods and POD Reduced Order Models, Proceedings of the 44th IEEE Conference on Decision and Control, 2006. ,
DOI : 10.1109/CDC.2005.1582209
URL : https://hal.archives-ouvertes.fr/inria-00336171
Trust-region methods, SIAM, 2000. ,
DOI : 10.1137/1.9780898719857
A hierarchy of low-dimensional models for the transient and post-transient cylinder wake, Journal of Fluid Mechanics, vol.497, pp.335-363, 2003. ,
DOI : 10.1017/S0022112003006694
Low-order modelling of laminar flow regimes past a confined square cylinder, Journal of Fluid Mechanics, vol.503, pp.161-170, 2004. ,
DOI : 10.1017/S0022112004007906
Optimisation aérodynamique par réduction de modèle POD et contrôle optimal Application au sillage laminaire d'un cylindre circulaire, 2004. ,
Optimal control of vortex shedding using low-order models. Part I?open-loop model development, International Journal for Numerical Methods in Engineering, vol.111, issue.224, pp.945-972, 1999. ,
DOI : 10.1002/(SICI)1097-0207(19990310)44:7<945::AID-NME537>3.0.CO;2-F
Numerical Optimization, 1999. ,
DOI : 10.1007/b98874
Flow control: new challenges for a new Renaissance, Progress in Aerospace Sciences, vol.37, issue.1, pp.21-58, 2001. ,
DOI : 10.1016/S0376-0421(00)00016-6
On the generation of a reverse von K??rm??n street for the controlled cylinder wake in the laminar regime, Physics of Fluids, vol.18, issue.2, pp.1-4, 2006. ,
DOI : 10.1063/1.2171193
Rotary oscillation control of a cylinder wake, Journal of Fluid Mechanics, vol.182, issue.-1, pp.77-90, 1991. ,
DOI : 10.1017/S0022112088001570
Optimal rotary control of the cylinder wake in the laminar regime, Physics of Fluids, vol.14, issue.7, pp.2073-2087, 2002. ,
DOI : 10.1063/1.1476671
