The magnus effect and windpowered ships, Naturwissenschaften, vol.13, issue.93, 1925. ,
The MEMS Handbook, 2002. ,
Flow control, 1995. ,
DOI : 10.1007/978-1-4612-2526-3
Flow Control: Passive, Active and Reactive Flow Management, 2000. ,
DOI : 10.1017/CBO9780511529535
Flow control: new challenges for a new Renaissance, Progress in Aerospace Sciences, 2001. ,
DOI : 10.1016/S0376-0421(00)00016-6
Proper Orthogonal Decomposition for Reduced Order Control of Partial Differential Equations, 2000. ,
A rigorous framework for optimization of expensive functions by surrogates, Structural Optimization, vol.16, issue.1, 1999. ,
DOI : 10.1007/BF01197708
A survey of model reduction methods for large-scale systems, Contemp. Math, vol.280, p.193, 2001. ,
DOI : 10.1090/conm/280/04630
The influence of control on proper orthogonal decomposition of wall-bounded turbulent flows, Physics of Fluids, vol.13, issue.2, p.520, 2001. ,
DOI : 10.1063/1.1333038
A Reduced-Order Method for Simulation and Control of Fluid Flows, Journal of Computational Physics, vol.143, issue.2, p.403, 1998. ,
DOI : 10.1006/jcph.1998.5943
Centroidal Voronoi Tessellation-Based Reduced-Order Modeling of Complex Systems, SIAM Journal on Scientific Computing, vol.28, issue.2, 2004. ,
DOI : 10.1137/5106482750342221x
Calibrated reduced-order POD-Galerkin system for fluid flow modelling, Journal of Computational Physics, vol.207, issue.1, p.192, 2005. ,
DOI : 10.1016/j.jcp.2005.01.008
A low-dimensional model for simulating three-dimensional cylinder flow, Journal of Fluid Mechanics, vol.458, p.181, 2002. ,
DOI : 10.1017/S0022112002007991
A hierarchy of low-dimensional models for the transient and post-transient cylinder wake, Journal of Fluid Mechanics, vol.497, p.335, 2003. ,
DOI : 10.1017/S0022112003006694
Vortex Dynamics in the Cylinder Wake, Annual Review of Fluid Mechanics, vol.28, issue.1, p.477, 1996. ,
DOI : 10.1146/annurev.fl.28.010196.002401
On some control problems in fluid mechanics, Theoretical and Computational Fluid Dynamics, vol.10, issue.4, p.303, 1990. ,
DOI : 10.1007/BF00271794
Active Control and Drag Optimization for Flow Past a Circular Cylinder, Journal of Computational Physics, vol.163, issue.1, p.83, 2000. ,
DOI : 10.1006/jcph.2000.6556
Suppression of vortex shedding for flow around a circular cylinder using optimal control, International Journal for Numerical Methods in Fluids, vol.11, issue.1, p.43, 2002. ,
DOI : 10.1002/fld.203
Optimal rotary control of the cylinder wake in the laminar regime, Physics of Fluids, vol.14, issue.7, p.2073, 2002. ,
DOI : 10.1063/1.1476671
Adjoint Equation-Based Methods for Control Problems in Incompressible, Viscous Flows, Flow, Turbulence and Combustion, vol.65, issue.3/4, p.249, 2000. ,
DOI : 10.1023/A:1011455900396
A trust-region framework for managing the use of approximation models in optimization, Icase report, pp.97-50, 1997. ,
DOI : 10.1007/BF01197433
Rotary oscillation control of a cylinder wake, Journal of Fluid Mechanics, vol.182, issue.-1, p.77, 1991. ,
DOI : 10.1017/S0022112088001570
Drag force in the open-loop control of the cylinder wake in the laminar regime, Physics of Fluids, vol.14, issue.2, p.810, 2002. ,
DOI : 10.1063/1.1432695
A global stability analysis of the steady and periodic cylinder wake, Journal of Fluid Mechanics, vol.74, issue.-1, p.297, 1994. ,
DOI : 10.1016/0167-2789(92)90021-E
Three-dimensional Floquet stability analysis of the wake of a circular cylinder, Journal of Fluid Mechanics, vol.199, issue.-1, p.215, 1996. ,
DOI : 10.1016/0021-9991(91)90007-8
Atmospheric Turbulence and Wave Propagation. The structure of inhomogeneous turbulence, pp.166-178, 1967. ,
in Lecture series 2002-04 on post-processing of experimental and numerical data (Von Kármán Institute for Fluid Dynamics, p.945, 1999. ,
Optimal control of vortex shedding using low-order models. Part II?model-based control, International Journal for Numerical Methods in Engineering, vol.44, issue.7, p.973, 1999. ,
DOI : 10.1002/(SICI)1097-0207(19990310)44:7<973::AID-NME538>3.0.CO;2-F
Optimisation aérodynamique par réduction de modèle POD et contrôle optimal Application au sillage laminaire d'un cylindre circulaire, 2004. ,
in Lecture series 2002-04 on post-processing of experimental and numerical data (Von Kármán Institute for Fluid Dynamics, 2002. ,
On the relation between the global modes and the spectra of drag and lift in periodic wake flows, Comptes Rendus M??canique, vol.331, issue.1, p.49, 2003. ,
DOI : 10.1016/S1631-0721(02)00018-9
Turbulence and the dynamics of coherent structures. Part 1: Coherent structures, Quarterly of Applied Mathematics XLV, p.561, 1987. ,
Low???dimensional models for complex geometry flows: Application to grooved channels and circular cylinders, Physics of Fluids A: Fluid Dynamics, vol.3, issue.10, p.2337, 1991. ,
DOI : 10.1063/1.857881
A Spectral Vanishing Viscosity Method for Large-Eddy Simulations, Journal of Computational Physics, vol.163, issue.1, p.22, 2000. ,
DOI : 10.1006/jcph.2000.6552
A spectral viscosity method for correcting the long-term behavior of POD models, Journal of Computational Physics, vol.194, issue.1, p.92, 2004. ,
DOI : 10.1016/j.jcp.2003.08.021
Optimal and robust control and estimation of linear paths to transition, Journal of Fluid Mechanics, vol.365, p.305, 1998. ,
DOI : 10.1017/S0022112098001281
DNS-based predictive control of turbulence: an optimal benchmark for feedback algorithms, Journal of Fluid Mechanics, vol.447, p.179, 2001. ,
DOI : 10.1017/S0022112001005821
Numerical simulation of the flow behind a rotary oscillating circular cylinder, Physics of Fluids, vol.10, issue.4, p.869, 1998. ,
DOI : 10.1063/1.869610
Trust-Region methods for flow control based on Reduced Order Modeling ,
