New interface
Journal articles
Multiple-step virtual screening using VSM-G: overview and validation of fast geometrical matching enrichment.
Abstract : Numerous methods are available for use as part of a virtual screening strategy but, as yet, no single method is able to guarantee both a level of confidence comparable to experimental screening and a level of computing efficiency that could drastically cut the costs of early phase drug discovery campaigns. Here, we present VSM-G (virtual screening manager for computational grids), a virtual screening platform that combines several structure-based drug design tools. VSM-G aims to be as user-friendly as possible while retaining enough flexibility to accommodate other in silico techniques as they are developed. In order to illustrate VSM-G concepts, we present a proof-of-concept study of a fast geometrical matching method based on spherical harmonics expansions surfaces. This technique is implemented in VSM-G as the first module of a multiple-step sequence tailored for high-throughput experiments. We show that, using this protocol, notable enrichment of the input molecular database can be achieved against a specific target, here the liver-X nuclear receptor. The benefits, limitations and applicability of the VSM-G approach are discussed. Possible improvements of both the geometrical matching technique and its implementation within VSM-G are suggested.
Complete list of metadata
https://hal.inria.fr/inria-00339119
Contributor : Malika Smail-Tabbone Connect in order to contact the contributor
Submitted on : Sunday, November 16, 2008 - 10:49:02 PM
Last modification on : Thursday, April 28, 2022 - 3:11:30 AM
Links full text
Identifiers
Collections
Citation
Alexandre Beautrait, Vincent Leroux, Matthieu Chavent, Léo Ghemtio, Marie-Dominique Devignes, et al.. Multiple-step virtual screening using VSM-G: overview and validation of fast geometrical matching enrichment.. Journal of Molecular Modeling, 2008, 14 (2), pp.135-148. ⟨10.1007/s00894-007-0257-9⟩. ⟨inria-00339119⟩
Share
Metrics
Record views
135
