Conference papers
Multi-sensor Fusion Method Using Bayesian Network for Precise Multi-vehicle Localization
Cherif Smaili 1 François Charpillet 1 Maan El Badaoui El Najjar 1, 2
1 MAIA - Autonomous intelligent machine
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
2 STF - Systèmes Tolérants aux Fautes
CRIStAL - Centre de Recherche en Informatique, Signal et Automatique de Lille - UMR 9189
Abstract : The multi-sensor fusion approach for multi-vehicle localization presented in this paper is based on the use of Bayesian network in order to fuse measurements sensors. For each vehicle, a Bayesian network is implemented to fuse measurement of embedded sensors. For the train of vehicle localization, a global Bayesian network is implemented in which we have modelled vehicles interconnections. The leader vehicle is supposed to be equipped by especially accurate sensors. With this approach, one can see that the follower's geo-positions computing are quite improved in using the Leader vehicle path and followers relative positioning provide for each follower using a rangefinder. Real data sensors are used to validate and to test the proposed approach. Experimental results are presented to shown approach performance.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00339316
Contributor : Cherif Smaili Connect in order to contact the contributor
Submitted on : Monday, November 17, 2008 - 3:19:27 PM
Last modification on : Wednesday, March 23, 2022 - 3:51:13 PM
Identifiers
  • HAL Id : inria-00339316, version 1
Citation
Cherif Smaili, François Charpillet, Maan El Badaoui El Najjar. Multi-sensor Fusion Method Using Bayesian Network for Precise Multi-vehicle Localization. The 11th International IEEE Conference on Intelligent Transportation Systems, Oct 2008, Beijing,, China. ⟨inria-00339316⟩
Share
Metrics
Record views
125
