Simple flexible skinning based on manifold modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper we propose a simple framework to compute flexible skinning weights, which allows the creation from quasi-rigid to soft deformations. We decompose the input mesh into a set of overlapping regions, in a way similar to the constructive manifold approach. Regions are associated to skeleton bones, and overlaps contain vertices influenced by several bones. A smooth transition function is then defined on overlaps, and is used to compute skinning weights. The size of overlaps can be tuned by the user, enabling an easy control of the desired type of deformations.
hetroy_et_al-grapp2009.pdf (2.15 Mo) Télécharger le fichier
paper19-video.wmv (28.22 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
inria-00339413 , version 1 (17-11-2008)
inria-00339413 , version 2 (23-05-2016)
  • HAL Id : inria-00339413 , version 2
Franck Hétroy, Cédric Gérot, Lin Lu, Boris Thibert. Simple flexible skinning based on manifold modeling. GRAPP 2009 - International Conference on Computer Graphics Theory and Applications, Feb 2009, Lisbonne, Portugal. pp.259-265. ⟨inria-00339413v2⟩
578 Consultations
580 Téléchargements
