Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, Epiciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Conference papers
Simple flexible skinning based on manifold modeling
Franck Hétroy 1, * Cédric Gérot 2 Lin Lu 3 Boris Thibert 4
* Corresponding author
1 EVASION - Virtual environments for animation and image synthesis of natural objects
Inria Grenoble - Rhône-Alpes, LJK - Laboratoire Jean Kuntzmann, Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology
2 GIPSA-GPIG - GIPSA - Géométrie, Perception, Images, Geste
GIPSA-DIS - Département Images et Signal
Abstract : In this paper we propose a simple framework to compute flexible skinning weights, which allows the creation from quasi-rigid to soft deformations. We decompose the input mesh into a set of overlapping regions, in a way similar to the constructive manifold approach. Regions are associated to skeleton bones, and overlaps contain vertices influenced by several bones. A smooth transition function is then defined on overlaps, and is used to compute skinning weights. The size of overlaps can be tuned by the user, enabling an easy control of the desired type of deformations.
Document type :
Conference papers
Complete list of metadata
Cited literature [20 references]  Display  Hide  Download
https://hal.inria.fr/inria-00339413
Contributor : Franck Hétroy-Wheeler Connect in order to contact the contributor
Submitted on : Monday, May 23, 2016 - 9:52:27 AM
Last modification on : Friday, February 4, 2022 - 3:22:46 AM
Long-term archiving on: : Wednesday, August 24, 2016 - 10:11:41 AM
Identifiers
  • HAL Id : inria-00339413, version 2
Citation
Franck Hétroy, Cédric Gérot, Lin Lu, Boris Thibert. Simple flexible skinning based on manifold modeling. GRAPP 2009 - International Conference on Computer Graphics Theory and Applications, Feb 2009, Lisbonne, Portugal. pp.259-265. ⟨inria-00339413v2⟩
Share
Metrics
Record views
539
Files downloads
552
