Numerical Methods for Nonsmooth Dynamical Systems, Lecture Notes in Applied and Computational Mechanics, vol.35, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00423530
An introduction to SICONOS, INRIA SICONOS open-source software available at, 2007. ,
Hirzinger, G: A passivity based Cartesian impedance controller for flexible joint robots -part II: full state feedback, impedance design and experiments, Proceedings ICRA '04, pp.2666-2672, 2004. ,
The Dynamics of Discrete Mechanical Systems with Perfect Unilateral Constraints, Archive for Rational Mechanics and Analysis, vol.154, issue.3, pp.199-274, 2000. ,
DOI : 10.1007/s002050000105
URL : https://hal.archives-ouvertes.fr/hal-00111308
Formulation and well-posedness of the dynamics of rigid-body systems with perfect unilateral constraints, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.359, issue.1789, pp.2327-2346, 2001. ,
DOI : 10.1098/rsta.2001.0854
Generalized solutions in systems with active unilateral constraints, Nonlinear Anal., Hybrid Syst, pp.510-526, 2007. ,
Dynamical Systems With Active Singularities of Elastic Type: A Modeling and Controller Synthesis Framework, IEEE Transactions on Automatic Control, vol.52, issue.1, pp.39-55, 2007. ,
DOI : 10.1109/TAC.2006.887899
TRACKING CONTROL OF COMPLEMENTARITY LAGRANGIAN SYSTEMS, International Journal of Bifurcation and Chaos, vol.15, issue.06, pp.1839-1866, 2005. ,
DOI : 10.1142/S0218127405013010
URL : https://hal.archives-ouvertes.fr/inria-00070619
Absolute stability and the Lagrange???Dirichlet theorem with monotone multivalued mappings, Systems & Control Letters, vol.51, issue.5, pp.343-353, 2004. ,
DOI : 10.1016/j.sysconle.2003.09.007
URL : https://hal.archives-ouvertes.fr/inria-00071792
Nonsmooth Mechanics, 1999. ,
URL : https://hal.archives-ouvertes.fr/hal-01236953
Dissipative Systems Analysis and Control, Theory and Applications, 2007. ,
DOI : 10.1007/978-1-84628-517-2
URL : https://hal.archives-ouvertes.fr/hal-01338369
On the control of finite-dimensional mechanical systems with unilateral constraints, IEEE Transactions on Automatic Control, vol.42, issue.2, pp.200-215, 1997. ,
DOI : 10.1109/9.554400
Global tracking controllers for flexiblejoint manipulators: a comparative study, Automatica, issue.7, pp.31-941, 1995. ,
Global asymptotic stabilization of the attitude and the angular rates of an underactuated non-symmetric rigid body, Automatica, vol.44, issue.7, pp.1781-1789, 2008. ,
DOI : 10.1016/j.automatica.2007.11.022
A sweeping process approach to inelastic contact problems with general inertia operators, European Journal of Mechanics - A/Solids, vol.26, issue.3, pp.474-490, 2007. ,
DOI : 10.1016/j.euromechsol.2006.07.002
Finite-dimensional Variational Inequalities and Complementarity Problems, 2003. ,
Trajectory tracking for a particle in elliptical billiards, International Journal of Control, vol.24, issue.2, pp.189-213, 2008. ,
DOI : 10.1103/PhysRevE.64.026212
Set Valued Force Laws: Dynamics of Non-Smooth Systems Lecture Notes in Applied Mechanics, 2001. ,
DOI : 10.1007/978-3-540-44479-4
Bangbang impact control using hybrid impedance/time-delay control, IEEE/AMSE Transactions on Mechatronics, vol.8, issue.2, pp.272-277, 2003. ,
Stability properties of equilibrium sets of non-linear mechanical systems with dry friction and impact, Nonlinear Dynamics, vol.43, issue.4, pp.551-583, 2008. ,
DOI : 10.1007/s11071-007-9244-z
UNIFORM CONVERGENCE OF MONOTONE MEASURE DIFFERENTIAL INCLUSIONS: WITH APPLICATION TO THE CONTROL OF MECHANICAL SYSTEMS WITH UNILATERAL CONSTRAINTS, International Journal of Bifurcation and Chaos, vol.18, issue.05, pp.1435-1457, 2008. ,
DOI : 10.1142/S0218127408021099
Stability and Convergence of Mechanical Systems with Unilateral Constraints, Lecture Notes in Applied and Computational Mechanics, vol.36, 2008. ,
DOI : 10.1007/978-3-540-76975-0
A unified variational model for the dynamics of perfect unilateral constraints, European Journal of Mechanics - A/Solids, vol.17, issue.5, pp.819-842, 1998. ,
DOI : 10.1016/S0997-7538(98)80007-7
Feedback stabilization and tracking of constrained robots, IEEE Transactions on Automatic Control, vol.33, issue.5, pp.419-426, 1988. ,
DOI : 10.1109/9.1220
Asymptotic tracking of periodic trajectories for a simple mechanical system subject to nonsmooth impacts, IEEE Transactions on Automatic Control, vol.46, issue.7, pp.1122-1126, 2001. ,
DOI : 10.1109/9.935068
Exponential and BIBS stabilisation of one degree of freedom mechanical systems subject to single non-smooth impacts, IEE Proceedings - Control Theory and Applications, vol.148, issue.2, pp.147-155, 2001. ,
DOI : 10.1049/ip-cta:20010366
Dynamic position feedback stabilisation of multidegrees-of-freedom linear mechanical systems subject to nonsmooth impacts, IEE Proceedings - Control Theory and Applications, vol.148, issue.6, pp.488-496, 2001. ,
DOI : 10.1049/ip-cta:20010713
Optimal control problems in hybrid systems with active singularities, Nonlinear Anal., Theory Methods Appl, pp.999-1017, 2006. ,
Passivity-based tracking control of multiconstraint complementarity Lagrangian systems, IEEE Conference on Decision and Control, vol.276264, 2008. ,
Unilateral contact and dry friction in finite freedom dynamics, Nonsmooth Mechanics and Applications, CISM Courses and Lectures, vol.302, 1988. ,
Control of contact problem in constrained Euler-Lagrange systems, IEEE Transactions on Automatic Control, vol.46, issue.10, pp.1595-1599, 2001. ,
DOI : 10.1109/9.956055
An Experimental Study of Planar Impact of a Robot Manipulator, IEEE/ASME Transactions on Mechatronics, vol.9, issue.1, pp.123-128, 2004. ,
DOI : 10.1109/TMECH.2004.823888
Impact stabilizing controller for hydraulic actuators with friction: Theory and experiments, Control Engineering Practice, vol.14, issue.12, pp.1423-1433, 2006. ,
DOI : 10.1016/j.conengprac.2005.10.007
Modeling and control of impact in mechanical systems: theory and experimental results, IEEE Transactions on Automatic Control, vol.44, issue.2, pp.294-309, 1999. ,
DOI : 10.1109/9.746255
Experimental Validation of Contact Dynamics Simulation of Constrained Robotic Tasks, The International Journal of Robotics Research, vol.19, issue.12, pp.1203-1217, 2000. ,
DOI : 10.1177/02783640022068039
A Theoretical and Experimental Investigation of Impact Control for Manipulators, The International Journal of Robotics Research, vol.12, issue.4, pp.351-365, 1993. ,
DOI : 10.1177/027836499301200403
Hirzinger: A new variable stiffness design: matching requirements of the next robot generation, Proceedings of the IEEE Int. Conf. on Robotics and Automation, pp.1741-1746, 2008. ,
Experimental study of contact transition control incorporating joint acceleration feedback, IEEE/ASME Transactions on Mechatronics, vol.5, issue.3, pp.292-301, 2000. ,
DOI : 10.1109/3516.868921
Design and implementation of a robust switching control scheme for a class of constrained robot tasks, International Journal of Systems Science, vol.13, issue.5, pp.303-321, 2006. ,
DOI : 10.1115/1.1344881
