A survey on tree edit distance and related problems, Theoretical Computer Science, vol.337, issue.1-3, p.217239, 2005. ,
DOI : 10.1016/j.tcs.2004.12.030
Apprentissage de structures d'arbres à partir d'exemples, Thèse, 2002. ,
Analysis of Tree Edit Distance Algorithms, Proceedings of the 14th annual symposium on Combinatorial Pattern Matching (CPM, p.8395, 2003. ,
DOI : 10.1007/3-540-44888-8_7
URL : https://hal.archives-ouvertes.fr/hal-00307516
Algorithms on strings, trees, and sequences, 1997. ,
Fast algorithms for nding nearest common ancestors, SIAM J. Comput, vol.13, issue.2, p.338355, 1984. ,
Pattern Matching in Trees, Journal of the ACM, vol.29, issue.1, pp.68-95, 1982. ,
DOI : 10.1145/322290.322295
A Fast Algorithm for Optimal Alignment between Similar Ordered Trees, Fundam. Inform, vol.56, issue.12, p.105120, 2003. ,
DOI : 10.1007/3-540-48194-X_22
Alignment of trees -an alternative to tree edit, CPM '94: Proceedings of the 5th Annual Symposium on Combinatorial Pattern Matching, p.7586, 1994. ,
Computing the edit-distance between unrooted ordered trees, ESA, p.91102, 1998. ,
A tree-edit-distance algorithm for comparing simple, closed shapes, SODA, p.696704, 2000. ,
A New Measure of Edit Distance between Labeled Trees, COCOON, p.338348, 2001. ,
DOI : 10.1007/3-540-44679-6_37
Nonlinear pattern matching in trees, J. ACM, vol.39, issue.2, p.295316, 1992. ,
A new measure of the distance between ordered trees and its applications, technical report 85166-cs, 1997. ,
Introduction to computational biology, 1997. ,
The Tree-to-Tree Correction Problem, Journal of the ACM, vol.26, issue.3, p.422433, 1979. ,
DOI : 10.1145/322139.322143
The string-to-string correction problem, J. ACM, vol.21, issue.1, p.168173, 1974. ,
Algorithms for the constrained editing distance between ordered labeled trees and related problems, Pattern Recognition, vol.28, issue.3, p.463474, 1995. ,
Simple Fast Algorithms for the Editing Distance between Trees and Related Problems, SIAM Journal on Computing, vol.18, issue.6, p.12451262, 1989. ,
DOI : 10.1137/0218082
Approximate Tree Matching in the Presence of Variable Length Don???t Cares, Journal of Algorithms, vol.16, issue.1, p.3366, 1994. ,
DOI : 10.1006/jagm.1994.1003
