A generic view of Dantzig–Wolfe decomposition in mixed integer programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Operations Research Letters Année : 2006
The Dantzig–Wolfe reformulation principle is presented based on the concept of generating sets. The use of generating sets allows for an easy extension to mixed integer programming. Moreover, it provides a unifying framework for viewing various column generation practices, such as relaxing or tightening the column generation subproblem and introducing stabilization techniques.
inria-00342623 , version 1 (27-11-2008)
François Vanderbeck, Martin W.P. Savelsbergh. A generic view of Dantzig–Wolfe decomposition in mixed integer programming. Operations Research Letters, 2006, 34 (3), pp.296-306. ⟨10.1016/j.orl.2005.05.009⟩. ⟨inria-00342623⟩
125 Consultations
0 Téléchargements
