Arrangements and their applications. Handbook of Computational Geometry, pp.49-119, 2000. ,
Meshing implicit algebraic surfaces: the smooth case, Mathematical Methods for Curves and Surfaces: Tromso'04, pp.11-26, 2005. ,
Visualisation of Implicit Algebraic Curves, 15th Pacific Conference on Computer Graphics and Applications (PG'07), pp.303-312, 2007. ,
DOI : 10.1109/PG.2007.32
URL : https://hal.archives-ouvertes.fr/inria-00175062
Computing the topology of real algebraic space curves, J. Symbolic Comput, vol.39, pp.719-744, 2005. ,
On the number of branches of a plane curve germ, Kodai Math. Journal, vol.9, pp.179-187, 1986. ,
Algorithms in Real Algebraic Geometry, 2003. ,
DOI : 10.1007/978-3-662-05355-3
URL : https://hal.archives-ouvertes.fr/hal-01083587
Algorithms for Reporting and Counting Geometric Intersections, IEEE Transactions on Computers, vol.28, issue.9, pp.643-647, 1979. ,
DOI : 10.1109/TC.1979.1675432
URL : http://www.dtic.mil/get-tr-doc/pdf?AD=ADA058768
Algorithmic geometry, 1998. ,
DOI : 10.1017/CBO9781139172998
Svlis: Introduction and user manual, 1994. ,
Interval methods in geometric modeling, Proceedings Geometric Modeling and Processing 2000. Theory and Applications, p.321, 2000. ,
DOI : 10.1109/GMAP.2000.838263
Determining the Topology of Real Algebraic Surfaces, Mathematics of Surfaces, number 3604 in LNCS, pp.121-146, 2005. ,
DOI : 10.1007/11537908_8
Quantifier elimination for real closed fields by cylindrical algebraic decompostion, Proc. 2nd GI Conference on Automata Theory and Formal Languages, pp.134-183, 1975. ,
DOI : 10.1007/3-540-07407-4_17
Extremal real algebraic geometry and a-discriminants, 2007. ,
Almost tight recursion tree bounds for the Descartes method, Proceedings of the 2006 international symposium on Symbolic and algebraic computation , ISSAC '06, pp.71-78, 2006. ,
DOI : 10.1145/1145768.1145786
Geometric constraint solver using multivariate rational spline functions, Proceedings of the sixth ACM symposium on Solid modeling and applications , SMA '01, pp.1-10, 2001. ,
DOI : 10.1145/376957.376958
IntroductionàIntroduction`Introductionà la résolution des systèmes polynomiaux, Mathématiques et Applications, vol.59, 2007. ,
Real algebraic numbers: Complexity analysis and experimentations. In Reliable Implementation of Real Number Algorithms: Theory and Practice, LNCS, p.page, 2008. ,
Curves and surfaces for computer aided geometric design : a practical guide. Comp. science and sci. computing, 1990. ,
Design patterns: elements of reusable objectoriented software, 1995. ,
Investigation of a subdivision based algorithm for solving systems of polynomial equations, Proceedings of the Third World Congress of Nonlinear Analysts, pp.167-178, 2001. ,
DOI : 10.1016/S0362-546X(01)00166-3
Computing the topology of 3- dimensional algebraic curves, Computational Methods for Algebraic Spline Surfaces, pp.27-44, 2005. ,
Efficient topology determination of implicitly defined algebraic plane curves, Computer Aided Geometric Design, vol.19, issue.9, pp.719-743, 2002. ,
DOI : 10.1016/S0167-8396(02)00167-X
A new approach to the surface intersection problem, Computer Aided Geometric Design, vol.14, issue.2, pp.111-134, 1997. ,
DOI : 10.1016/S0167-8396(96)00024-6
Arrangements, Handbook of Discrete and Computational Geometry, pp.529-562, 2004. ,
DOI : 10.1201/9781420035315.ch24
Arrangements and their applications in robotics: recent developments, WAFR: Proceedings of the workshop on Algorithmic foundations of robotics, pp.495-511 ,
An exact, complete and efficient computation of arrangements of B??zier curves, Proceedings of the 2007 ACM symposium on Solid and physical modeling , SPM '07, pp.253-263, 2007. ,
DOI : 10.1145/1236246.1236282
Guaranteed consistency of surface intersections and trimmed surfaces using a coupled topology resolution and domain decomposition scheme, Advances in Computational Mathematics, 2007. ,
DOI : 10.1007/s10444-005-7539-5
Computing arrangements using subdivision and interval arithmetic, Proceedings of the Sixth International Conference on Curves and Surfaces Avignon, 2006. ,
Contouring 1- and 2-manifolds in arbitrary dimensions, International Conference on Shape Modeling and Applications 2005 (SMI' 05), pp.218-227, 2005. ,
DOI : 10.1109/SMI.2005.10
Efficient and exact manipulation of algebraic points and curves, Computer-Aided Design, vol.32, issue.11, pp.649-662, 2000. ,
DOI : 10.1016/S0010-4485(00)00054-3
The local degree of a smooth mapping, Sakharth. SSR Mecn. Akad. Moambe, vol.85, issue.2, pp.309-312, 1977. ,
Subdivision Methods for the Topology of 2d and 3d Implicit Curves, Computational Methods for Algebraic Spline Surfaces, 2006. ,
DOI : 10.1007/978-3-540-72185-7_11
URL : https://hal.archives-ouvertes.fr/inria-00130216
Degree theory, Cambridge Tracts in Mathematics, issue.73, 1978. ,
Marching cubes: A high resolution 3D surface construction algorithm, ACM SIGGRAPH Computer Graphics, vol.21, issue.4, pp.163-170, 1987. ,
DOI : 10.1145/37402.37422
Calculating approximate curve arrangements using rounded arithmetic, Proceedings of the fifth annual symposium on Computational geometry , SCG '89, pp.197-207, 1989. ,
DOI : 10.1145/73833.73856
An approximate arrangement algorithm for semi-algebraic curves, SCG '06: Proceedings of the twenty-second annual symposium on Computational geometry, pp.237-246, 2006. ,
Subdivision methods for solving polynomial equations, Journal of Symbolic Computation, vol.44, issue.3, 2005. ,
DOI : 10.1016/j.jsc.2008.04.016
URL : https://hal.archives-ouvertes.fr/inria-00070350
Bernstein's basis and real root isolation, Mathematical Sciences Research Institute Publications, pp.459-478, 2005. ,
On the computation of an arrangement of quadrics in 3D, Special issue, 19th European Workshop on Computational Geometry, pp.145-164, 2005. ,
DOI : 10.1016/j.comgeo.2004.05.003
URL : https://hal.archives-ouvertes.fr/inria-00350858
Isotopic meshing of a real algebraic surface, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00070499
On the Complexity of Isolating Real Roots and Computing with Certainty the Topological Degree, Journal of Complexity, vol.18, issue.2, pp.612-640, 2002. ,
DOI : 10.1006/jcom.2001.0636
Isotopic approximation of implicit curves and surfaces, Proceedings of the 2004 Eurographics/ACM SIGGRAPH symposium on Geometry processing , SGP '04, pp.245-254, 2004. ,
DOI : 10.1145/1057432.1057465
SCCI-HYBRID METHODS FOR 2D CURVE TRACING, International Journal of Image and Graphics, vol.05, issue.03, pp.447-480, 2005. ,
DOI : 10.1142/S0219467805001859
Interactive Visualization of Implicit Surfaces with Singularities, Implicit Surfaces, pp.73-87, 1996. ,
DOI : 10.1111/1467-8659.00196
Algorithm for algebraic curve intersection, Computer-Aided Design, vol.21, issue.9, pp.547-554, 1989. ,
DOI : 10.1016/0010-4485(89)90015-8
Computation of the solutions of nonlinear polynomial systems, Computer Aided Geometric Design, vol.10, issue.5, pp.379-405, 1993. ,
DOI : 10.1016/0167-8396(93)90019-Y
Computing the topological degree of a mapping inR n, Numerische Mathematik, vol.2, issue.1, pp.23-38, 1975. ,
DOI : 10.1007/BF01419526
On the number of branches of a $1$-dimensional semianalytic set, Kodai Mathematical Journal, vol.11, issue.1, pp.78-85, 1988. ,
DOI : 10.2996/kmj/1138038822
Modern computer algebra, 1999. ,
DOI : 10.1017/CBO9781139856065
A Subdivision Arrangement Algorithm for Semi-Algebraic Curves: An Overview, 15th Pacific Conference on Computer Graphics and Applications (PG'07), pp.449-452, 2007. ,
DOI : 10.1109/PG.2007.18
URL : https://hal.archives-ouvertes.fr/inria-00189560
Jacobi Curves: Computing the Exact Topology of Arrangements of Non-singular Algebraic Curves, ESA 2003, pp.532-543, 2003. ,
DOI : 10.1007/978-3-540-39658-1_49
A quick intersection algorithm for arbitrary polygons, Spring Conference on Computer Graphics -SCCG98, pp.195-204, 1998. ,
