Abstract : We prove convergence and optimal complexity of an adaptive mixed finite element algorithm, based on the lowest-order Raviart–Thomas finite element space. In each step of the algorithm, the local refinement is either performed using simple edge residuals or a data oscillation term, depending on an adaptive marking strategy. The inexact solution of the discrete system is controlled by an adaptive stopping criterion related to the estimator.
