Another efficient algorithm for convex hulls in two dimensions, Information Processing Letters, vol.9, issue.5, pp.216-219, 1979. ,
DOI : 10.1016/0020-0190(79)90072-3
Exact linear algebra -lep mla 1 ,
Generic Programming and the STL, 1998. ,
Algorithm engineering for a geometric computing library, 1997. ,
Computational Solutions of Matrix Problems Over an Integral Domain, IMA Journal of Applied Mathematics, vol.10, issue.1, pp.68-104, 1972. ,
DOI : 10.1093/imamat/10.1.68
Exacus: Efficient and Exact Algorithms for Curves and Surfaces, Proc. 13th Annu. European Sympos. Algorithms (ESA'05), pp.155-166, 2005. ,
DOI : 10.1007/11561071_16
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.121.4351
Designing and Implementing a General Purpose Halfedge Data Structure, Proc. International Workshop on Algorithm Engineering (WAE'01), pp.51-66, 2001. ,
DOI : 10.1007/3-540-44688-5_5
Interval arithmetic yields efficient dynamic filters for computational geometry, Discrete Applied Mathematics, vol.109, issue.1-2, pp.25-47, 2001. ,
DOI : 10.1016/S0166-218X(00)00231-6
Applications of the Generic Programming Paradigm in the Design of CGAL, Generic Programming?Proceedings of a Dagstuhl Seminar, 2000. ,
DOI : 10.1007/3-540-39953-4_16
The LEDA class real number, 1996. ,
Curiously recurring template patterns, C++ Report, pp.24-27, 1995. ,
Computational Geometry: Algorithms and Applications, 1997. ,
Systems of distinct representatives and linear algebra, Journal of Research of the National Bureau of Standards Section B Mathematics and Mathematical Physics, vol.71, issue.4, pp.241-245, 1967. ,
DOI : 10.6028/jres.071B.033
Towards and open curved kernel, Proceedings of the twentieth annual symposium on Computational geometry , SCG '04, pp.438-446, 2004. ,
DOI : 10.1145/997817.997882
The CGAL kernel: A basis for geometric computation, Proc. 1st ACM Workshop on Appl, pp.191-202, 1996. ,
DOI : 10.1007/BFb0014496
On the design of CGAL a computational geometry algorithms library, Software: Practice and Experience, vol.12, issue.11, pp.11-1167, 2000. ,
DOI : 10.1002/1097-024X(200009)30:11<1167::AID-SPE337>3.0.CO;2-B
A generic lazy evaluation scheme for exact geometric computations, Proc. 2nd Library-Centric Software Design, pp.75-84, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00089229
Static analysis yields efficient exact integer arithmetic for computational geometry, ACM Transactions on Graphics, vol.15, issue.3, pp.223-248, 1996. ,
DOI : 10.1145/231731.231735
Look --- a Lazy Object-Oriented Kernel for geometric computation, Proceedings of the sixteenth annual symposium on Computational geometry , SCG '00, pp.99-118, 2002. ,
DOI : 10.1145/336154.336196
PlaGeo, a library for planar geometry, and SpaGeo, a library for spatial geometry, 1994. ,
GMP, the GNU multiple precision arithmetic library ,
An Adaptable and Extensible Geometry Kernel, Proc. Workshop on Algorithm Engineering, pp.79-90, 2001. ,
DOI : 10.1007/3-540-44688-5_7
URL : https://hal.archives-ouvertes.fr/inria-00344964
The C++ Standard Library, A Tutorial and Reference, 1999. ,
Using generic programming for designing a data structure for polyhedral surfaces, Computational Geometry, vol.13, issue.1, pp.65-90, 1999. ,
DOI : 10.1016/S0925-7721(99)00007-3
Classroom Examples of Robustness Problems in Geometric Computations, Proc. 12th European Symposium on Algorithms, pp.702-713, 2004. ,
DOI : 10.1007/978-3-540-30140-0_62
URL : https://hal.archives-ouvertes.fr/inria-00344515
Recent progress in exact geometric computation, The Journal of Logic and Algebraic Programming, vol.64, issue.1, pp.85-111, 2005. ,
DOI : 10.1016/j.jlap.2004.07.006
URL : https://hal.archives-ouvertes.fr/inria-00344355
The Exact Solution of Systems of Linear Equations with Polynomial Coefficients, Journal of the ACM, vol.20, issue.4, pp.563-588, 1973. ,
DOI : 10.1145/321784.321787
A Platform for Combinatorial and Geometric Computing, 2000. ,
Generic programming, 1st Intl. Joint Conf. of ISSAC-88 and AAEC-6, pp.13-25, 1989. ,
DOI : 10.1007/3-540-51084-2_2
Algorithm-oriented generic libraries, Software: Practice and Experience, vol.21, issue.7, pp.623-642, 1994. ,
DOI : 10.1002/spe.4380240703
Traits: A new and useful template technique, C++ Report, 1995. ,
Designing the computational geometry algorithms library CGAL, Proc. 1st ACM Workshop on Appl, pp.53-58, 1996. ,
DOI : 10.1007/BFb0014484
What is generic programming? In Workshop on Library-Centric Software Design (LCSD'05), 2005. ,
Designing a computational geometry algorithms library Research Report MPI-I-97-1-014, Max-Planck-Institut für Informatik, 1997. ,
A Case Study on the Cost of Geometric Computing, Proc. Workshop on Algorithm Engineering and Experimentation, pp.156-176, 1999. ,
DOI : 10.1007/3-540-48518-X_10
Adaptive Precision Floating-Point Arithmetic and Fast Robust Geometric Predicates, Discrete & Computational Geometry, vol.18, issue.3, pp.305-363, 1997. ,
DOI : 10.1007/PL00009321
The Boost Graph Library, 2002. ,
The C++ Programming Language, 1997. ,
Techniques for scientific C++, 2000. ,
Generic programming in CGAL, the Computational Geometry Algorithms Library, Proceedings of the 6th Eurographics Workshop on Programming Paradigms in Graphics, pp.127-138, 1997. ,
THE EXACT COMPUTATION PARADIGM, Computing in, pp.452-492, 1995. ,
DOI : 10.1142/9789812831699_0011
