Reduced order approaches for variational data assimilation in oceanography - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
A reduced order approach for 4D-Var data assimilation is presented in the context of a tropical Pacific ocean model. The control space is defined as the span of a few vectors representing a significant part of the system variability, while the model itself is not reduced. It is shown that such an approach can lead to significant improvements, both in terms of the quality of the solution and of the computational efficiency, with regard to data assimilation with a full control vector. However several limitations of the approach will also be discussed, as well as a first step towards an hybrid variational-sequential algorithm.
Fichier non déposé
inria-00344504 , version 1 (04-12-2008)
  • HAL Id : inria-00344504 , version 1
Eric Blayo. Reduced order approaches for variational data assimilation in oceanography. Workshop on Industrial applications of low order model based on POD, Mar 2008, Bordeaux, France. ⟨inria-00344504⟩
87 Consultations
0 Téléchargements
