Another efficient algorithm for convex hulls in two dimensions, Information Processing Letters, vol.9, issue.5, pp.216-219, 1979. ,
DOI : 10.1016/0020-0190(79)90072-3
Applications of random sampling in computational geometry, II, Discrete & Computational Geometry, vol.1, issue.5, pp.387-421, 1989. ,
DOI : 10.1007/BF02187740
Delaunay triangulations in three dimensions with finite precision arithmetic, Computer Aided Geometric Design, vol.9, issue.6, pp.457-470, 1992. ,
DOI : 10.1016/0167-8396(92)90044-P
Numerical stability of algorithms for line arrangements, Proceedings of the seventh annual symposium on Computational geometry , SCG '91, pp.334-341, 1991. ,
DOI : 10.1145/109648.109685
Computational geometry in practice Fundamental Algorithms for Computer Graphics, volume F17 of NATO ASI, pp.707-724, 1985. ,
What every computer scientist should know about floating-point arithmetic, ACM Computing Surveys, vol.23, issue.1, pp.5-48, 1990. ,
DOI : 10.1145/103162.103163
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.1.7712
An efficient algorith for determining the convex hull of a finite planar set, Information Processing Letters, vol.1, issue.4, pp.132-133, 1972. ,
DOI : 10.1016/0020-0190(72)90045-2
A perturbation scheme for spherical arrangements with application to molecular modeling, Comp. Geom.: Theory and Applications, vol.10, 1998. ,
Efficient Delaunay triangulation using rational arithmetic, ACM Transactions on Graphics, vol.10, issue.1, pp.71-91, 1991. ,
DOI : 10.1145/99902.99905
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.475.2747
Constructing strongly convex hulls using exact or rounded arithmetic, SoCG'90, pp.235-243, 1990. ,
DOI : 10.1007/bf01758851
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.48.6674
Calculating approximate curve arrangements using rounded arithmetic, Proceedings of the fifth annual symposium on Computational geometry , SCG '89, pp.197-207, 1989. ,
DOI : 10.1145/73833.73856
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.52.1864
The LEDA Platform for Combinatorial and Geometric Computing, 1018. ,
Adaptive precision floating-point arithmetic and fast robust geometric predicates, Discrete & Computational Geometry, vol.18, pp.305-363, 1997. ,
Topology-Oriented Implementation--An Approach to Robust Geometric Algorithms, Algorithmica, vol.27, issue.1, pp.5-20, 2000. ,
DOI : 10.1007/s004530010002
Robust geometric computation, Handbook of Discrete and Computational Geometry, chapter 41, 2004. ,
DOI : 10.1007/978-0-387-30162-4_349
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.7.3934
